| peerless locked up? | |
simplicity14twin Member
Age : 26 Join date : 2014-01-13 Points : 4114 Posts : 112 Location : New Hampshire
| Subject: peerless locked up? January 16th 2014, 8:11 am | |
| I have a peerless sitting around that I want to use but is locked up. I have never done transaxle work so i dont know if I should take it apart or not? I can put up some pics at a later time | |
Age : 49 Join date : 2012-04-23 Points : 5701 Posts : 1091 Location : Galion, OH
| Subject: Re: peerless locked up? January 16th 2014, 8:15 am | |
| Take it apart! Just make sure if you're not used to doing this kind of thing to set everything out as you take it apart in a way that helps you remember how it goes back together. One thing to watch for is the little steel ball in the shifter assembly that tends to drop into the oil/grease when you split the case. | |
| Subject: Re: peerless locked up? January 16th 2014, 9:09 am | |
| i think i will open her up on saturday ile put on some pics | |
Age : 57 Join date : 2013-12-21 Points : 4805 Posts : 744 Location : Salem Illinois
| Subject: Re: peerless locked up? January 16th 2014, 9:32 am | |
| Take it apart... I've found that a piece of cardboard, with the bolt pattern drawn on is a great way to make sure you get the bolts back in the right holes (punch holes in the cardboard where the bolts are in the transfer case)
I use this method with head bolts on cars, and it always insures that you have the RIGHT bolt in the RIGHT hole.
| Subject: Re: peerless locked up? January 16th 2014, 10:19 am | |
| well it is kind of weird because i was plowing with the mower (mtd service star) then all of the sudden it stopped moving. I then fired it up and the belt was spinning but it was slipping around the pulley on the trans axle so i think that maybe a spider gear or something is screwed up maybe but idk. | |
| Subject: Re: peerless locked up? January 16th 2014, 10:44 am | |
| if it's a spider, it wont matter... you're gonna weld them solid anyway
| Subject: peerless locked up? January 16th 2014, 10:48 am | |
| pretty straight forward, just take the cover off and look for chunks of sintered steel........... | |
Age : 49 Join date : 2012-04-05 Points : 5701 Posts : 959 Location : Mansfield, Ohio
| Subject: Re: peerless locked up? January 16th 2014, 11:23 am | |
| Typically there is a spring loaded ball, underneath a set screw, on top. Just don't loose the spring and ball when you take cover off.
Also, there is a bolt under the pulley that needs to come out. Pulley has to come off to see it. | |
| | | | Sponsored content
| Who is online? | In total there are 80 users online :: 0 Registered, 0 Hidden and 80 Guests
