| 22 X 11 on a locked mst205 | |
Warren Evans Member
Age : 52 Join date : 2016-11-30 Points : 3020 Posts : 83 Location : Greenville, IL.
| Subject: 22 X 11 on a locked mst205 December 15th 2016, 8:28 pm | |
| Im looking at some ITP Mudlites 22x11x8 for a prodject and it has a locked mst 205 Im just wondering if that would be to hard on the axle? | |
| | | Doug Site Owner
| Subject: Re: 22 X 11 on a locked mst205 December 15th 2016, 8:36 pm | |
| It might be ok if the transaxle has bearings installed, either internally or externally. Otherwise it would probably be pretty hard on the trans. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| | | Warren Evans Member
| Subject: Re: 22 X 11 on a locked mst205 December 15th 2016, 8:50 pm | |
| I just picked up some bearings for it I do have another mst 205 That isnt locked wondering if that would be a better choice with them tires? | |
| Subject: Re: 22 X 11 on a locked mst205 December 15th 2016, 9:47 pm | |
| Well, how is it locked? The doc locker IMO is the "best" way, though not the easiest. Fozzy is definitely easiest, but I feel like thats hard on the gears. Maine Mud Mower filled the whole diff with molten zinc. And @Fearlessfront welded the spider gears to the shaft (the free spinning ones that share the shaft in the bull gear). In order of strength (IMO): 1. Doc Locker 2. Solid zinc casting 3. Welding the spider gears to the pin 4. Fozzy locker 1 or 2 would be fine with those big tires, and number 3 would be ok if you're certain you got a good hot weld. But I wouldn't try it if you just fozzy locked it. | |
| | | Warren Evans Member
| Subject: Re: 22 X 11 on a locked mst205 December 17th 2016, 10:45 am | |
| I weld the spiders to the pin and I use a stick welder for better penatration with hardedned rods | |
| | | Doug Site Owner
| Subject: Re: 22 X 11 on a locked mst205 December 17th 2016, 12:54 pm | |
| Fozzy lock works great from my experience. Less stress on the gears than welding the gears to the pin. Remember, these gears are sintered steel. In a Fozzy lock, the teeth are just stopped from rotating, where in a pin lock everything is trying to twist the gears off that pin. A lot more force is being applied that way. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| | | Warren Evans Member
| | | | Warren Evans Member
| | | | Sponsored content
| Who is online? | In total there are 35 users online :: 0 Registered, 0 Hidden and 35 Guests
