 Lifted Murray
SkiLLz
Murray modder
dked41
Craftsman Dude
gearheadmike
AcreFarm
greener179
98Murray
Tractor Man Jeff
Chopperhed
Theworktractor
matthew sidor
MurrayMudderr
22 posters
gearheadmike
Lifted Murray - Page 2 Empty
PostSubject: Re: Lifted Murray   Lifted Murray - Page 2 Icon_minitimeJanuary 17th 2013, 9:01 pm
maybe some frame stiffining supports,as i noticed its the pressed style frame and i know they like to flex as i got the same frame lol , its looking good tho!
PostSubject: Re: Lifted Murray   Lifted Murray - Page 2 Icon_minitimeJanuary 18th 2013, 5:49 pm
Ive seen dynamarks and MTD's with the huskee name on them - its either a different model name from AYP or stores that sell them - like yardman, mastercut , white, ect.
MurrayMudderr
MurrayMudderr
PostSubject: Re: Lifted Murray   Lifted Murray - Page 2 Icon_minitimeJanuary 19th 2013, 8:01 pm
what do you mean by frame supports?
Craftsman Dude
Craftsman Dude
PostSubject: Re: Lifted Murray   Lifted Murray - Page 2 Icon_minitimeJanuary 19th 2013, 9:42 pm
BUMPERS!!!! Front and rear .
Chopperhed
Chopperhed
PostSubject: Re: Lifted Murray   Lifted Murray - Page 2 Icon_minitimeJanuary 19th 2013, 10:23 pm
Stamped steel, bolt together frames are pretty weak angle iron reinforcement is usually a good thing. Some (like me) go to a full tube steel frame.
Anything you can do to stiffen the chassis helps in holding thind together.
MurrayMudderr
MurrayMudderr
PostSubject: Re: Lifted Murray   Lifted Murray - Page 2 Icon_minitimeJanuary 20th 2013, 11:25 am
How do i go about putting bigger tires on the tires i wanna put on are i think a 5 bolt pattern but the ones on the mower are just the single shaft if the center how could i make the new ones work?
dked41
dked41
PostSubject: Re: Lifted Murray   Lifted Murray - Page 2 Icon_minitimeJanuary 20th 2013, 2:21 pm
Find some 5 bolt hubs, my Montgomry wards has 5 bolt hubs on the 3/4" transaxle shafts.
MurrayMudderr
MurrayMudderr
PostSubject: Re: Lifted Murray   Lifted Murray - Page 2 Icon_minitimeJanuary 21st 2013, 6:06 pm
Well guys got the bumper done and most of the back have alot of grinding to do lol. On the rear end should i box that front in too or leave it open??
Lifted Murray - Page 2 Murray14
Lifted Murray - Page 2 Murray16
Lifted Murray - Page 2 Murray17
Let me know what i should do next love hearing what you guys think!!
dked41
dked41
PostSubject: Re: Lifted Murray   Lifted Murray - Page 2 Icon_minitimeJanuary 22nd 2013, 11:45 am
I would close up the gaps in the rear box, just for looks. Next thing to do is the 15" rims and tires !!!
MurrayMudderr
MurrayMudderr
PostSubject: Re: Lifted Murray   Lifted Murray - Page 2 Icon_minitimeJanuary 22nd 2013, 5:38 pm
I think i might box it in its just it will be harder to get to the chain is all. Im also looking at putting old pick up tires on there!
MurrayMudderr
MurrayMudderr
PostSubject: Re: Lifted Murray   Lifted Murray - Page 2 Icon_minitimeJanuary 23rd 2013, 7:35 am
Well ill let everyone know what i get done today
MurrayMudderr
MurrayMudderr
PostSubject: Re: Lifted Murray   Lifted Murray - Page 2 Icon_minitimeFebruary 10th 2013, 10:57 am
hey guys sorry i havent posted anything for a while i will hopefully have some pics tomorrow but as of right now its kinda hard to explain what i did to it.
Murray modder
Murray modder
PostSubject: Re: Lifted Murray   Lifted Murray - Page 2 Icon_minitimeFebruary 10th 2013, 11:39 am
Even if your weld are perfect, I really would plan on adding some supports for the front axle, It's never fun to hit a rock and slam your work into the ground...I do a little sword work and a while back I had the sord breakoff directly after the weld, SO I hope it wouldnt happen on a bigger scale like this.
MurrayMudderr
MurrayMudderr
PostSubject: Re: Lifted Murray   Lifted Murray - Page 2 Icon_minitimeFebruary 11th 2013, 5:44 pm
How in the hell do i get my freaking tires off the axle i had a big mess cause it wouldnt come off
PostSubject: Re: Lifted Murray   Lifted Murray - Page 2 Icon_minitimeFebruary 11th 2013, 6:21 pm
Are they bolt or clip?
Either way, the way I got my tires off my MTD FNR axle was to take the bolt off the end, and using a grooved piece of metal (like angle iron, I used a metal green fence post) and nestle it over the inner shaft of the rim from the backside and tapped on it till my tire popped off.
Can be hard though. Might want to wait and see if anybody has anything better to say.
Be sure that when you put your rim back on the axxle to use never-seize or some grease to help with it not sticking.
SkiLLz
PostSubject: Re: Lifted Murray   Lifted Murray - Page 2 Icon_minitimeFebruary 14th 2013, 12:40 am
WD-40
Torch
Hammer
Big punch
Lots of cussing
MurrayMudderr
MurrayMudderr
PostSubject: Re: Lifted Murray   Lifted Murray - Page 2 Icon_minitimeFebruary 14th 2013, 10:34 am
They have E clips i get the rim to the end of the axle and thats it.
Chopperhed
Chopperhed
PostSubject: Re: Lifted Murray   Lifted Murray - Page 2 Icon_minitimeFebruary 14th 2013, 11:01 am
Sounds like the end of the axle might be mushroomed a bit. It could be just a ridge caused by the wheel moving a bit on the axle.
Slide the wheel back and file the ends of the axles to make sure there is no ridge or something holding them back.
Had the same problem on a PTO shaft the while back. Had to get inside the U joint with a die grinder and grind the end of the axle down a bit
MurrayMudderr
MurrayMudderr
PostSubject: Re: Lifted Murray   Lifted Murray - Page 2 Icon_minitimeFebruary 17th 2013, 10:39 pm
Well come tuesday when i go to school i will try grinding the axle down just a bit and hope that it comes! Wish me luck!!
MurrayMudderr
MurrayMudderr
PostSubject: Re: Lifted Murray   Lifted Murray - Page 2 Icon_minitimeMarch 31st 2013, 9:59 am
Hey guys sorry i havent posted anything so heres my new up date put 15in tires on the front and im waiting on some back tires i also put front fenders on but dont have a picture yet
Lifted Murray - Page 2 Murray13
Thats why i need bigger back tires
Lifted Murray - Page 2 Murray11
Theres the front
Let me know what i should do next!!
PostSubject: Re: Lifted Murray   Lifted Murray - Page 2 Icon_minitimeMarch 31st 2013, 10:41 am
Looks good.
What kind of rear tires are you getting for it.
Mabe you cold do a foot throttal>
MurrayMudderr
MurrayMudderr
PostSubject: Re: Lifted Murray   Lifted Murray - Page 2 Icon_minitimeApril 2nd 2013, 6:04 pm
I getting 14in rear tires because 15 will make it sit forward too much and im planning on doing a foot throttle when its all done
MurrayMudderr
MurrayMudderr
PostSubject: Re: Lifted Murray   Lifted Murray - Page 2 Icon_minitimeJune 1st 2013, 3:46 pm
hey guys sorry i havent been keeping you all up to date on the lifted murray mudder. will i got the big tires all on and its painted black now and i found a 20.5 hp motor for it and got it on the other night now i need help with my hood the motor is too big idk how to put my hood back on
Lifted Murray - Page 2 Murray12
PostSubject: Re: Lifted Murray   Lifted Murray - Page 2 Icon_minitimeJune 1st 2013, 6:50 pm
I would bend the sides of the hood out to fit around the opposed.
PostSubject: Re: Lifted Murray   Lifted Murray - Page 2 Icon_minitimeJune 1st 2013, 7:08 pm
I had the same problem trying to fit an 18hp oppy twin under the hood of my racer (which originally had an 11hp single. I made a large cutout along each side of the hood, and filled it in with a flared out section. If you want, you can just make the cutouts and leave it at that.
PostSubject: Re: Lifted Murray   Lifted Murray - Page 2 Icon_minitimeJune 1st 2013, 8:18 pm
if you leave the cut out, i would suggest getting some of the stuff they use to cover the edges, give it a cleaner look
btw those tires look good on there to me, this thing has came a long way man good work
Lifted Murray
» Lifted Murray 4x4
» Off-Road Lifted Mud Monster MURRAY 20Hp Peerless 820 Style
» Lifted Murray paint job
» lifted murray mud mmower
» 74 lifted Murray mudder "TRAILBOSS II"
