 differential braking.....
crafsmankiller
jaymz_eric
6 posters
jaymz_eric
differential braking..... Empty
PostSubject: differential braking.....   differential braking..... Icon_minitimeNovember 14th 2012, 10:02 am
has anyone figured out how to do differential braking on a mower yet? I think it would be sweet to be able to swing the front end around like you can a farm tractor lol I know i could use it in the woods when pullin out trees for firewood
crafsmankiller
PostSubject: Re: differential braking.....   differential braking..... Icon_minitimeNovember 15th 2012, 11:35 am
I guess you could. You would need a brake on each axle even though that would basicly make it a zero turn
Chopperhed
Chopperhed
PostSubject: Re: differential braking.....   differential braking..... Icon_minitimeNovember 15th 2012, 6:49 pm
A brake on each axle would do it just fine. It wouldn't be a zero turn since a ZT reverses one wheel while the other one is going forward. It would give a very small turn radius. Remember that the unbraked wheel will speed up as the braked axle slows down
N1ck
N1ck
PostSubject: Re: differential braking.....   differential braking..... Icon_minitimeMarch 14th 2015, 10:48 pm
i have thought about doing this so you could have a unlocked dif and still be able to have it posish kinda like some Toyota trucks have.
PostSubject: Re: differential braking.....   differential braking..... Icon_minitimeMarch 14th 2015, 11:19 pm
Diff brake is far from posi. Its made to lock one axle or the other so the opposite spins.
N1ck
N1ck
PostSubject: Re: differential braking.....   differential braking..... Icon_minitimeMarch 14th 2015, 11:26 pm
it works on full size tractors
PostSubject: Re: differential braking.....   differential braking..... Icon_minitimeMarch 15th 2015, 1:02 am
Full size tractors usually have limited slip or differential locks. If you try a diff brake setup on a straight axle, it wont work.
Moose
Moose
PostSubject: Re: differential braking.....   differential braking..... Icon_minitimeMarch 15th 2015, 12:19 pm
I messed around on a 4020 with the dual brakes it's ok for tight turns and all but it won't help if your stuck most of the time it will just burn up your brake.
» Cheap braking solution
» Limited Slip Differential
» Peerless 2600 hi and low , locking differential
» making the rearend posi/lock the rear differential
All-Terrain Lawn Tractor Forum :: Technical Forum :: Drivetrain & Brake Tech :: Brake Support-
