| | making the rearend posi/lock the rear differential | |
Guest Guest
![making the rearend posi/lock the rear differential Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | dangeroustoys56 Veteran Member
![dangeroustoys56](https://2img.net/u/2812/37/66/46/avatars/4-60.jpg)
Age : 53 Join date : 2010-02-10 Points : 7002 Posts : 1726 Location : Florida, USA
![making the rearend posi/lock the rear differential Empty](https://2img.net/i/empty.gif) | Subject: Re: making the rearend posi/lock the rear differential February 17th 2010, 6:09 am | |
| Most people weld them- however it needs to be really clean or the welds will fail- most racers that use locked transmissions actually add an extra set of spider gears bolted in . The absolute best way is to run at least a 1" straight axle.
Keep in mind locking the differential action will make it really hard to turn corners tho. | |
| ![Go down](https://2img.net/i/empty.gif) | | Chunk Established Member
![Chunk](https://2img.net/u/2812/37/66/46/avatars/2-3.jpg)
Age : 33 Join date : 2010-02-10 Points : 6146 Posts : 779 Location : Angus, Scotland
![making the rearend posi/lock the rear differential Empty](https://2img.net/i/empty.gif) | Subject: Re: making the rearend posi/lock the rear differential February 17th 2010, 8:03 am | |
| Yup, dangerous toys summed it up in a oner. Most people weld up the spider gears in the rear end so they cant move indepentantly. I didnt wanna do that to mine, but ended up with a spare tranny, so I have an extra two spider gears to play with now. That way I can lock and, and go back if I need to.
What kind of tranny are you running? | |
| ![Go down](https://2img.net/i/empty.gif) | | Guest Guest
![making the rearend posi/lock the rear differential Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | arild365 Member
![arild365](https://2img.net/u/2812/37/66/46/avatars/6-25.jpg)
Age : 29 Join date : 2010-02-11 Points : 5739 Posts : 320 Location : Canada, BC
![making the rearend posi/lock the rear differential Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Guest Guest
![making the rearend posi/lock the rear differential Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Chunk Established Member
![making the rearend posi/lock the rear differential Empty](https://2img.net/i/empty.gif) | Subject: Re: making the rearend posi/lock the rear differential February 18th 2010, 7:34 am | |
| Yeah - its a matter of preference i guess- a couple new mods im making will have straight axles , so ill find out how they work- i chose them over a differential because i wanted to dump alot of power n speed into it.
My sorta current mudder is a well used 80's agway all stock - i changed the front wheels to a treaded tire ( originals were the flat type) for more turning grip, removed the deck and went mudding in the swamp behind the folks house - surprisingly it does a really good job, even with a 3speed trans and unlocked trans, only time i really got stuck was when i chewed up the mud to make it really thick - i doubt even chains or AG tires would help then. | |
![making the rearend posi/lock the rear differential Empty](https://2img.net/i/empty.gif) | Subject: Re: making the rearend posi/lock the rear differential February 18th 2010, 9:56 am | |
| Hey i got a question about the trans. Ive had it for well over 3 years and never thought about oil/liquid in the tranny. Ive been gettin comments on youtube saying i should put some in. My question is what should i put in, if i need to put anything in and how? | |
![making the rearend posi/lock the rear differential Empty](https://2img.net/i/empty.gif) | Subject: Re: making the rearend posi/lock the rear differential February 18th 2010, 12:27 pm | |
| If you're running above stock speed, which you are, the stock grease in the tranny will be flung off the gears, so there is nothing lubricating them. It'll start whining pretty bad, and could blow. You just want to get yourself some heavy weight gear oil and will the case at about half way. If you really wanna go all out, drill and tap yourself a proper fill hole, and drain plug. Some racers also put in breathers, althought I dont think that's essential. There's a good chance the oil may leak from the seals, that's normal too, just keep it topped up. Only other thing I'll mention is that you should try to keep your input shaft well lubed. Maybe fit a grease fitting if you know how.
Alot of people mod their pulley and forgot about the tranny. They're only supposed to do about 5mph, anything more will kill them. It's pretty easy to do, and will keep your tranny lasting alot longer.
Hope that's what youre after man. | |
| ![Go down](https://2img.net/i/empty.gif) | | Webmaster Webmaster
![Webmaster](https://2img.net/u/2812/37/66/46/avatars/1-56.png)
![Webmaster Webmaster](https://i.servimg.com/u/f62/19/56/75/89/y310.png)
Age : 14 Join date : 2010-02-09 Points : 5661 Posts : 332 Location : Here!
![making the rearend posi/lock the rear differential Empty](https://2img.net/i/empty.gif) | Subject: Re: making the rearend posi/lock the rear differential February 18th 2010, 6:55 pm | |
| Interesting Fearlessfront: Id say the only real way would be run a actual car differential way shortened - i dont think theres enough room to mount to mount some sort of air locker in a lawntractor trans .
Grease in a lawntractor trans- i agree with CSAKvids- stock grease wont cut it ( first hand experience trashing a stock trans)- i think theres some sort of oil seals you can get for a lawntractor trans- not sure what itd be , might need to do a lil machining as well to make em fit ( match one up at autoparts?)- use an oil resistant RTV ( keep it away from the inside)- fill the trans 1/2 full- heaviest gear oil y can find ( i used lucas oil additive actually). Another trick ive seen is to drill n tap holes in the axle tubes to pump some heavy grease in there as well with 90 degree grease zerks.
Any way to keep grease/oil in there will keep it together longer. | |
| ![Go down](https://2img.net/i/empty.gif) | | Mississippi1313 Member
![Mississippi1313](https://2img.net/u/2812/37/66/46/avatars/9-96.jpg)
Age : 29 Join date : 2010-02-14 Points : 5385 Posts : 47 Location : Ole Goula
![making the rearend posi/lock the rear differential Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Sponsored content
![making the rearend posi/lock the rear differential Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | | making the rearend posi/lock the rear differential | |
| Who is online? | In total there are 124 users online :: 0 Registered, 0 Hidden and 124 Guests
