| splined pulley | |
greener179 Member
| Subject: splined pulley October 22nd 2012, 5:16 pm | |
| does anyone know where to buy a splined pulley? | |
| | | moremorelawnmowers Member
Age : 27 Join date : 2012-08-04 Points : 4626 Posts : 86 Location : New York, Amsterdam
| Subject: Re: splined pulley October 22nd 2012, 7:50 pm | |
| I dont know where to buy one but my MTD had a splined pulley on the transaxle and when I pulley swaped it I just bought a normal pulley with a key way slot and a set screw. To attach it I placed it on the input shaft and snapped off a piece of a small screw driver and put it in the key way slot. Lastly I tightened down the set screw and have not had a problem to this day. Its not the right way but it works. | |
| | | greener179 Member
| Subject: Re: splined pulley October 22nd 2012, 8:59 pm | |
| would it work to buy a keyed one just a little to small tap it on and drill a hole through the input shaft and put a bolt through it? | |
| | | Chopperhed Moderator
| Subject: Re: splined pulley October 22nd 2012, 9:42 pm | |
| might be able to find a splined hub and get a weld on sprocket for it.
Or find something that has the correct spline, and have it machined to fit a weldable sprocket. | |
| | | greener179 Member
| Subject: Re: splined pulley October 22nd 2012, 9:49 pm | |
| i dont know i just want to drop kick my trans right now because i cant find anything with the right splines so i might try to do the bolt thing | |
| Subject: Re: splined pulley October 22nd 2012, 9:55 pm | |
| what was on the original spline, do you have it?
Do you have a pic of it?
know any machinists?
There is always a way, but sometimes it take a bit of work and/or money
Nothing to get freaked over. | |
| | | greener179 Member
| Subject: Re: splined pulley October 22nd 2012, 10:03 pm | |
| i got the orignal middle of the pulley i just dont have anyone to weld for me | |
| | | W1ldyOvvnZ Member
Age : 28 Join date : 2011-12-06 Points : 5248 Posts : 499 Location : Winchester, ON, Canada
| Subject: Re: splined pulley October 22nd 2012, 10:36 pm | |
| look on craigslist or Kijiji can see if anyone has posted ads wanting to do welding repairs etc. and ask them how much it would cost if you prep it for them and get them to weld it, or go to a garage or something and ask them if someone can weld it up for you, I know where I live I got a couple garages that didn't mind doing it for a couple bucks until I got my own and worked at a machine shop. | |
| | | greener179 Member
| | | | greener179 Member
| Subject: Re: splined pulley October 23rd 2012, 8:27 pm | |
| ok i got my pulley on how do you change the belt with that varible pulley? | |
| | | | | splined pulley | |
| Who is online? | In total there are 30 users online :: 0 Registered, 0 Hidden and 30 Guests
