 What pulley can I get.
zlkahn1
What pulley can I get. Empty
PostSubject: What pulley can I get.   What pulley can I get. Icon_minitimeSeptember 16th 2018, 4:57 pm
Hello all,
I am in talks with an owner about a John Deere l100 15hp 6speed. I intend to do a rear pulley swap to get in the range of 20-30 mph. I am looking at 2-3 inch pulleys but don't know what pulleys are compatible with this mower. does anyone have experience with this?
PostSubject: Re: What pulley can I get.   What pulley can I get. Icon_minitimeSeptember 16th 2018, 6:46 pm
Basically you need a pulley with a 1” bore. I have a mud mower top speed calculator that I can use to help you select the right pulley. I get mine from this guy:
https://m.ebay.com/itm/100s-of-V-Belt-Pulleys-3-1-2-4-4-1-2-Steel-Pulley-w-Weld-Hub-All-Bores/391495762301?hash=item5b26f7417d%3Am%3Amw4C3LaZfVf3U9IOCF5TW9A%3Asc%3AUSPSPriorityMailSmallFlatRateBox%2114522%21US%21-1&var=660664927356
PostSubject: Re: What pulley can I get.   What pulley can I get. Icon_minitimeSeptember 16th 2018, 7:46 pm
Actually for a rear pulley I believe it would be a 5/8" keyed bore. 1" would work for the engine though.
Also for what it's worth I think a 2 or 3 inch trans pulley is a bit small, might have some slippage issues.
zlkahn1
PostSubject: Re: What pulley can I get.   What pulley can I get. Icon_minitimeSeptember 16th 2018, 7:56 pm
I anyone sure about this rear pulley bore? I want to get the order in asap.
PostSubject: Re: What pulley can I get.   What pulley can I get. Icon_minitimeSeptember 16th 2018, 8:13 pm
Well 5/8" is the standard size for LT transaxles, but you should probably be measuring yours before you go spending money on a pulley.
PostSubject: Re: What pulley can I get.   What pulley can I get. Icon_minitimeSeptember 16th 2018, 8:51 pm
You probably have a Spicer 4360 or something like that, I believe it'd be a 5/8" bore. And I wouldn't go under 4" on the rear pulley, you're gonna have some belt slip if you do. I'd have a 6" deck pulley modified for a drive pulley and a 4" on the rear to get the kind of speeds you want. Make sure your brakes are operable and your steering is tight too, death wobble is kind of terrifying on a lightweight mower.
» PULLEY HELP
» Pulley help
» pulley help
» What is this called on my Pulley?
» I need help with my pulley swap! :(
