| What is this called on my Pulley? | |
+3Ropertractor14 akcender W1ldyOvvnZ 7 posters | Author | Message |
W1ldyOvvnZ Member
Age : 28 Join date : 2011-12-06 Points : 5246 Posts : 499 Location : Winchester, ON, Canada
| Subject: What is this called on my Pulley? December 10th 2011, 2:10 pm | |
| I am planning on doing a Pulley swap on my MTD and took the pulley off of the trans and found that it didn't have a keyway, just groves. Heres a Picture of it, what would you call this? Im also wondering where can I get this style of pulley in a 4" diameter that will fit on a 3/4" shaft? Any websites(id prefer if they could ship to Canada but I have a postbox in the US), or stores to suggest(I'm going out to Princess Auto and maybe later on TSC). | |
| | | akcender Member
Age : 29 Join date : 2011-12-04 Points : 4815 Posts : 46 Location : Toronto, Ontario, Canada
| | | | W1ldyOvvnZ Member
| Subject: Re: What is this called on my Pulley? December 10th 2011, 6:13 pm | |
| I checked pricess auto since I was in the city anyways and they only have ones with a keyway, hopefully TSC will have them. If not I know someone with a lawn tractor scrap yard that might have one. | |
| | | Ropertractor14 Member
Age : 110 Join date : 2010-02-23 Points : 5466 Posts : 84 Location : Nova Scotia, Canada
| | | | CityRedneck Member
Age : 28 Join date : 2011-08-13 Points : 5139 Posts : 241 Location : Winter Park
| Subject: Re: What is this called on my Pulley? December 10th 2011, 9:59 pm | |
| craftsman has those (only those.) went to buy me a new pulley for a swap and they only had drive pulleys with splines. I do believe that Chunk posted a potic that has cheap pulleys. (phoniex pulleys) thats the name. | |
| | | W1ldyOvvnZ Member
| Subject: Re: What is this called on my Pulley? December 11th 2011, 12:36 am | |
| I checked http://www.phoenix-mfg.com/ and they look like they all have keyways. What did you do for a pulley swap them CityRedneck? Could I just take another MTD Pulley(or the 7" I have now and cut it then install the center into another pulley? | |
| | | F150F250F350 Member
Age : 29 Join date : 2011-09-28 Points : 4860 Posts : 52 Location : Oskaloosa Iowa
| Subject: I have one December 22nd 2011, 9:04 pm | |
| Do you have one yet if not I have an old one that I don't need it is 3.5'' and if you reply with your in side dementions I can see if they match mine but I don't know how you would measure that. | |
| | | W1ldyOvvnZ Member
| Subject: Re: What is this called on my Pulley? December 22nd 2011, 10:37 pm | |
| I checked some stuff on the pulley, It fits on a 3/4 inch shaft, it has 48 splines, and im pretty sure its 1" wide(the part that fits on the transmission shaft, I used a micrometer backwards and subtracted the number I got from the total length of my micrometer). If you look at the end of the shaft you might see it has a stopper(looks like a washer welded onto the end of the pulley). Heres a Picture If you don't really understand what I just said: | |
Age : 54 Join date : 2010-02-10 Points : 7071 Posts : 1726 Location : Florida, USA
| Subject: Re: What is this called on my Pulley? December 23rd 2011, 7:15 am | |
| Or a cheeper method is to cut the splined pulley up to sit flush on another pulley and weld them together - only thing is it has to set level with the belt drive .
I welded a splined adapter into a different pulley on my mod MTD - belt was too high ( wasnt level ) and caused them to chew up belts . | |
| | | W1ldyOvvnZ Member
| Subject: Re: What is this called on my Pulley? December 23rd 2011, 8:33 am | |
| - dangeroustoys56 wrote:
- Or a cheeper method is to cut the splined pulley up to sit flush on another pulley and weld them together - only thing is it has to set level with the belt drive .
I welded a splined adapter into a different pulley on my mod MTD - belt was too high ( wasnt level ) and caused them to chew up belts . I don't want to chew up belts, I know I can weld it properly but My welder is a cheap welder like harbor freight welders and I have .030mm wire in a .032mm wire feeder so the wire doesn't come out fast enough to make a useable weld and its flux core so If I do any welding I have to do it at school. I am probably going to do it if the tractor dealership down the road from me cant get one(Ive gotten everything I want from them without waiting more then 2 weeks but its pricy, probably $50 for the pulley I am looking for). Also what I could see happening is that I weld the pulley on sideways so it wobbles. and slips off. Heres a Picture with the Clutch Engaged on how it looks with the 7" Pulley. The reason why I can't change the Front pulley is because the belt goes from a vertical shaft pulley to a horizontal shaft pulley. | |
| | | W1ldyOvvnZ Member
| Subject: Re: What is this called on my Pulley? December 23rd 2011, 8:48 am | |
| - F150F250F350 wrote:
- Do you have one yet if not I have an old one that I don't need it is 3.5'' and if you reply with your in side dementions I can see if they match mine but I don't know how you would measure that.
I forgot to say yeah i still need a pulley. I havent been able to go and check TSC, or my friends lawn tractor junk yard. | |
| | | gearheadmike Member
Age : 34 Join date : 2011-11-18 Points : 5201 Posts : 392 Location : west chazy ny
| | | | W1ldyOvvnZ Member
| | | | gearheadmike Member
| Subject: Re: What is this called on my Pulley? December 23rd 2011, 1:00 pm | |
| yea i was just at tsc and for my 8'' pulley and the hub to weld it on total of $24 in just too cheap lol so i made my own | |
| | | W1ldyOvvnZ Member
| Subject: Re: What is this called on my Pulley? December 23rd 2011, 2:09 pm | |
| - gearheadmike wrote:
- yea i was just at tsc and for my 8'' pulley and the hub to weld it on total of $24 in just too cheap lol so i made my own
Im probably going to do it your way, unless I can find a hub that would work for my transmission or find a pulley that is exactly what I want. | |
| Who is online? | In total there are 9 users online :: 0 Registered, 0 Hidden and 9 Guests
