| Pulley Question | |
+3Chunk Ropertractor14 indianaboy93 7 posters |
Chunk Established Member
| Subject: Re: Pulley Question June 10th 2010, 5:10 am | |
| I follwed you the first time lol. It should stretch fairly easily then. Did you say the next size was too big? | |
indianaboy93 Member
Age : 31 Join date : 2010-03-14 Points : 5572 Posts : 195
| Subject: Re: Pulley Question June 10th 2010, 6:44 am | |
| - Chunk wrote:
- I follwed you the first time lol. It should stretch fairly easily then. Did you say the next size was too big?
no, the first time the guy read the wrong part number and gave me the wrong belt. i think i need 3/4 of an inch of stretch. do you think i'll get it? | |
| Subject: Re: Pulley Question June 10th 2010, 7:22 am | |
| Well, you want them a lil tight- otherwise theyd slip and fall off. Rubber belts should stretch a bit.
My murray was like that- like i mentioned- didnt matter really if i had the clutch in or not- i think that one was a tad tight- but the shift on the go trans made for easy shifts- no clutching. | |
indianaboy93 Member
| Subject: Re: Pulley Question June 10th 2010, 7:34 am | |
| i just really hope this one stretches and quits grabbing when i'm engaging the clutch | |
| Subject: Re: Pulley Question June 10th 2010, 1:25 pm | |
| It will stretch, Im not sure about 3/4" though. May be wrong though (I do that sometimes ) Surely if its the correct length belt for the tractor it should work? | |
indianaboy93 Member
| Subject: Re: Pulley Question June 10th 2010, 3:04 pm | |
| - Chunk wrote:
- It will stretch, Im not sure about 3/4" though. May be wrong though (I do that sometimes )
Surely if its the correct length belt for the tractor it should work? If it won't stretch i will just get another belt. i'd only be out 17 dollars for this belt | |
| Subject: Re: Pulley Question June 10th 2010, 3:19 pm | |
| Can you not take it back? $17 isnt too bad, its never a bad thing having a wide selection of belts lying about! | |
indianaboy93 Member
| Subject: Re: Pulley Question June 10th 2010, 3:25 pm | |
| - Chunk wrote:
- Can you not take it back? $17 isnt too bad, its never a bad thing having a wide selection of belts lying about!
i don't think i can. since i've ran the mower and drove it some i think it would be non-returnable. if i had just slipped it on and off then i would be able to return it, i've done that before but after is been used i don't think they'll take it back | |
Guest Guest
| Subject: Re: Pulley Question June 10th 2010, 5:03 pm | |
| depends if its damaged... a sneaky tactic is to use black shoe polish to brighten it up |
| Subject: Re: Pulley Question June 10th 2010, 5:36 pm | |
| Usually when i get a belt n its the wrong size- i keep it for something else- never know , and you wouldnt need to go buy it. | |
indianaboy93 Member
indianaboy93 Member
| Subject: Re: Pulley Question June 11th 2010, 6:46 am | |
| Indianaboy93 : Yepper - its good to have spare belts - over the years ive collected quite a few spare belts - saves me trips to buy a new one constantly. | |
indianaboy93 Member
| Subject: Re: Pulley Question June 11th 2010, 3:36 pm | |
| Ive never had to replace any brake pads on my tractors - well only the ones with whole missing brake caliper n stuff.... | |
indianaboy93 Member
| Subject: Re: Pulley Question June 11th 2010, 3:42 pm | |
| - dangeroustoys56 wrote:
- Ive never had to replace any brake pads on my tractors - well only the ones with whole missing brake caliper n stuff....
thats good. but if i have to replace it i have a junk yardmachines(MTD) that i can grab the brake off of | |
| Subject: Re: Pulley Question June 11th 2010, 4:02 pm | |
| I have a ton of those things- calipers, pads, rotors from all my parts tractors .... | |
indianaboy93 Member
| Subject: Re: Pulley Question June 12th 2010, 4:13 am | |
| Sounds like that worked out well then! Mine gets a mittle crazy in 5th and 6th especially. This shifter nob sounds like it will be cool! Cant wait to see what you come up with | |
Webmaster Webmaster
Age : 14 Join date : 2010-02-09 Points : 5732 Posts : 332 Location : Here!
| Subject: Re: Pulley Question June 12th 2010, 5:59 pm | |
| Glad to hear that you got it going. it's always fun to ride the fruits of your labor! | |
indianaboy93 Member
| Subject: Re: Pulley Question June 12th 2010, 9:41 pm | |
| - FearlessFront wrote:
- Glad to hear that you got it going. it's always fun to ride the fruits of your labor!
yes!! and it was different because i've never had crawling abilities. with the old setup it went to fast and the belt slipped alot. yesterday i was crawling over stumps and dirt. i didn't think 1 mph could be so fun. lol | |
| Pulley Question | |
