 clutch help!!!
Go to page : Previous  1, 2
greener179
clutch help!!! - Page 2 Empty
PostSubject: Re: clutch help!!!   clutch help!!! - Page 2 Icon_minitimeSeptember 30th 2012, 3:45 pm
well clutch is least of my worries went to change oil yesteday and it was putting new oil in and it was coming right out the bottom by the shaft and there is a little hole by the shaft is that hole suspose to be there and if so what part goes in the hole?
Jamus
Jamus
PostSubject: Re: clutch help!!!   clutch help!!! - Page 2 Icon_minitimeOctober 3rd 2012, 5:52 pm
Not sure what this "hole" you are talking about is. If you need a lower crank seal it's a cheap part. If you need a lot of parts check out tewarehouse.com I get a lot of stuff from there, cheap but you pretty much pay $9 in shipping regardless of order size.
Got that clutch off and took some pics for ya. I didn't fully weld it yet, mainly was mocking it up to test. Then I forgot about it and ran it on the spotty weld job, haha.
clutch help!!! - Page 2 Img_2310
clutch help!!! - Page 2 Img_2311
clutch help!!! - Page 2 Img_2312
clutch help!!! - Page 2 Img_2313
http://www.rcbashers.com
greener179
greener179
PostSubject: Re: clutch help!!!   clutch help!!! - Page 2 Icon_minitimeOctober 3rd 2012, 9:46 pm
thanks for the pictues of that I was really interested but i think the hole is for it you build to much pessure but i got a new seal on and put make a gasket under it and after i put it on i put more make a gasket on.
clutch help!!!
» Using the pto clutch as a drive clutch
» Clutch set up
» electric clutch
» Clutch set-up advice
» Clutch problem
