 Clutch problem
Kody6
8 posters
Kody6
Kody6
Clutch problem Empty
PostSubject: Clutch problem   Clutch problem Icon_minitimeJuly 21st 2013, 7:04 pm
I just changed my pulleys and belts and now wen I push the clutch in the tractor still moves. what do I do?
PostSubject: Re: Clutch problem   Clutch problem Icon_minitimeJuly 21st 2013, 7:31 pm
Longer belt, or more travel in the clutch required.
Kody6
Kody6
PostSubject: Re: Clutch problem   Clutch problem Icon_minitimeJuly 21st 2013, 8:09 pm
I tried lots of different size belts and it don't do a difference
PostSubject: Re: Clutch problem   Clutch problem Icon_minitimeJuly 21st 2013, 9:18 pm
if you can take a pick of your belt when the clutch is pushed in all the way.
PostSubject: Re: Clutch problem   Clutch problem Icon_minitimeJuly 21st 2013, 9:44 pm
Did you put extra tensioners on if so it might be to tight and is the clutch hooked up right?
http://www.lastdropgarage.com
PostSubject: Re: Clutch problem   Clutch problem Icon_minitimeJuly 21st 2013, 11:35 pm
Yes check all of your belt tensioners and your clutch adjustment.
Another thing make sure that your belt doesn't have any sticky material on it, but I don't know if that will do it or not but still it wouldn't hurt.
PostSubject: Re: Clutch problem   Clutch problem Icon_minitimeJuly 21st 2013, 11:57 pm
I always have that problem with a new belt. they seem to have a coating on them that makes them very grabby. I usually go out and put it in the highest gear I have, then slip the belt for 50 ft or so then drive around for a couple minutes. then slip the belt again and repeat. after about a half hour they seem to get a glaze on them that slips nice when the clutch is in and grips when you let it out. Also you can look at putting in a belt brake like wheel horse has. basically a tab welded off the frame and a tab made that rides with the clutch that pinch the belt after the clutch is applied to stop the belt from moving
Kody6
Kody6
PostSubject: Re: Clutch problem   Clutch problem Icon_minitimeJuly 22nd 2013, 8:28 am
Thanks I will try that
PostSubject: Re: Clutch problem   Clutch problem Icon_minitimeJuly 22nd 2013, 10:27 am
Hopefully I can get Rainbow to draw up what I am writing about...
Using our gate system of guides we use a upper and lower bar across the frame of the tractor, so the belt is held at the right height. Then we weld two bars vertical on the bars, so when the clutch is pushed in, it keeps the belt in a oval shape, and off the pulley. If not the belt can be loose, and still grab, making it hard to shift.
This also allows us to use belts that are just barely large enough.
PostSubject: Re: Clutch problem   Clutch problem Icon_minitimeJuly 22nd 2013, 4:18 pm
Clutch problem Beltop10
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
Kody6
Kody6
PostSubject: Re: Clutch problem   Clutch problem Icon_minitimeJuly 22nd 2013, 4:25 pm
Thanks when I had my old pulleys on that's what it did but I was not sure how to do on a bigger pulley
PostSubject: Re: Clutch problem   Clutch problem Icon_minitimeJuly 23rd 2013, 7:34 am
Very nice Dan, we need to keep that in the standard reply file....
Kody6
Kody6
PostSubject: Re: Clutch problem   Clutch problem Icon_minitimeJuly 24th 2013, 2:06 pm
If I have a 5 inch pulley on the motor how seperated would the 2 vertical bars have to be
PostSubject: Re: Clutch problem   Clutch problem Icon_minitimeJuly 24th 2013, 2:24 pm
The way we would figure that out is to put the belt on, let the clutch out so the belt is tight, and put the bar maybe a finger's width away from the belt. Mark where it goes, take the belt off and weld it in.
Chaos Build
Haspin 2021 thread
Kody6
Kody6
PostSubject: Re: Clutch problem   Clutch problem Icon_minitimeJuly 24th 2013, 2:30 pm
Would this work even if the pulley on the engine is the same size as the clutch pulley
PostSubject: Re: Clutch problem   Clutch problem Icon_minitimeJuly 24th 2013, 3:13 pm
Not sure what the clutch pulley's size has to do with it. Our belt gates are bars are welded in to the frame above and below the belt, across the underside of the tractor frame, and close to the engine pulley (but with enough room you can slip the belt through to change it.) They are not connected to the clutch at all.
Chaos Build
Haspin 2021 thread
Kody6
Kody6
PostSubject: Re: Clutch problem   Clutch problem Icon_minitimeJuly 24th 2013, 3:30 pm
Oh k sorry I dint really under stand but now I do thanks
Kody6
Kody6
PostSubject: Re: Clutch problem   Clutch problem Icon_minitimeJuly 25th 2013, 7:52 pm
Great another problem with my clutch whenever I start driving my belt gets twisted anybody know why?http://illiweb.com/fa/pbucket.gif?o=0&newest=1
It gets twisted where I'm pointing at but the only reason it's not right now is because I took it off and put it back on
Kody6
Kody6
PostSubject: Re: Clutch problem   Clutch problem Icon_minitimeJuly 25th 2013, 7:53 pm
PostSubject: Re: Clutch problem   Clutch problem Icon_minitimeJuly 26th 2013, 8:53 am
Hard to tell from that picture, but are you running a V style clutch pulley on the back of the belt? That might be your problem.
Chaos Build
Haspin 2021 thread
Kody6
Kody6
PostSubject: Re: Clutch problem   Clutch problem Icon_minitimeJuly 26th 2013, 9:37 am
PostSubject: Re: Clutch problem   Clutch problem Icon_minitimeJuly 26th 2013, 9:44 am
If its on the back side of the belt, you need a flat pulley
Clutch problem John-Deere-Flat-Idler-Pulley-am124346-large
Chaos Build
Haspin 2021 thread
Kody6
Kody6
PostSubject: Re: Clutch problem   Clutch problem Icon_minitimeJuly 26th 2013, 9:52 am
Oh sorry ya I'm runing a flat pulley on the back side of the belt
Clutch problem
» Hard Clutch Engagement Problem
» MTD 175/105 clutch slipping
» clutch assy
» Clutch set up
» gas pedal??????
