 MTD 175/105 clutch slipping
Mazyk
MTD 175/105 clutch slipping Empty
PostSubject: MTD 175/105 clutch slipping   MTD 175/105 clutch slipping Icon_minitimeApril 5th 2019, 1:20 am
Hello everybody. This is my first post on this forum and I am sorry if this question already accured.
And sorry if my english is bad, I am writing from Europe/Slovenija.
So the question:
I have MTD 175/105 silvertrak and has this clutch assembly (it is manual).
It is 2 years old and it is already slipping. Has this clutch samo sort of setup, that you can tighten it? I have already disassembled the old one and I don't remember if i has.
I found this video xxx and it is the same as mine. can I put some washer under the clutch ring that it will be higher and it would have more friction?
thanks for all answers.
best regards, Matjaž
since I am the new member I cannot post external links.
PostSubject: Re: MTD 175/105 clutch slipping   MTD 175/105 clutch slipping Icon_minitimeApril 5th 2019, 9:58 am
You should be able to post links. On the toolbar next to the youtube icon is a chain with a green/white + on it. Try using that.
MTD 175/105 clutch slipping Sig115PROJECTS:
MTD 175/105 clutch slipping Sig214MTD 175/105 clutch slipping Sig314
PostSubject: Re: MTD 175/105 clutch slipping   MTD 175/105 clutch slipping Icon_minitimeApril 5th 2019, 10:12 am
Is it one of the vari-drive deals? My John Deere 110 with the JD variator (they're pretty similar) had that issue once, and I fixed it by getting a new front belt.
» Using the pto clutch as a drive clutch
» clutch help!!!
» Belt flipping and slipping. Hey that rhymes!
» Craftsman skipping/slipping steering fix
» Electric pto clutch
