| clutch assy | |
noledroByrreK Member
Age : 30 Join date : 2011-01-14 Points : 5373 Posts : 252 Location : DFW Texas
| Subject: clutch assy January 15th 2011, 9:03 pm | |
| Alright so i think i am having a clutch issue that i might no the answer to i just to wanted to make sure. Right now i have the clutch bout midway between the engine and the transaxle and i have a idler/tenser pulley between the engine and clutch pulley. i did some light testing i had it up on a cynderblock an put it in first gear. when i press in the clutch nothing happens... the tires keep on spinning. could it be cuz theres no load on it or should i move the idler pulley to the other side of the clutch(in between the clutch and the trans axle)?
thanks | |
| | | Jordan Member
Age : 30 Join date : 2010-10-03 Points : 5355 Posts : 170 Location : Ontario Canada
| Subject: Re: clutch assy January 15th 2011, 9:49 pm | |
| id try putting the tires on the ground and see what happens but if it moves just back the tensioner off a bit | |
| Subject: Re: clutch assy January 15th 2011, 10:03 pm | |
| ill try that.. i think its getting slack enuf. the clutch is on the edge of the right side and when fulley depresses it will hit the other side. i had to put a stopper in so it would stop just before hitting . alsotho aner question i had was when you push in the clutch is it supposed to make it slip on the rear or engine pulley?
thanks | |
| | | Jordan Member
| Subject: Re: clutch assy January 15th 2011, 10:11 pm | |
| it should slip at the engine, well the belt should come away from the pulley so its not touching it at all but if its touching its ok | |
| Subject: Re: clutch assy January 15th 2011, 10:23 pm | |
| in that case i think i should move my idler because most of the slack is going to the rear. i think if i didn't have a idler in between the clutch and engine it would help ill have to test that tommorow | |
| Subject: Re: clutch assy January 16th 2011, 3:22 am | |
| Check Fearlessfronts builds- he did a racing lawntractor clutch setup - something like this: | |
| Subject: Re: clutch assy January 16th 2011, 12:37 pm | |
| hmm maybe i can try and build one like the one you posted on my build | |
| Subject: Re: clutch assy January 16th 2011, 4:22 pm | |
| Should be able to mess around n build one from plain steel- those billet ones are for those high dollar racers. | |
| | | | | clutch assy | |
| Who is online? | In total there are 24 users online :: 0 Registered, 0 Hidden and 24 Guests
