| TMJ's Craftsman LT1000 Conversion Thread | |
+43camomanusa Andy from Chenango Forks 1997 Murray Krawler86 FOSWMT Doc Sprocket Murray modder MurrayMayhem megamudder redlinemotorsportts richie thomas xxXMowerdudeXxx Thunderdivine killerbob11122 crafsmankiller THE MTD GUY Doug BlackMountian88 dagr8tim truckin42 dked41 Chopperhed Josh Blair W1ldyOvvnZ Craftsman Dude greener179 TennesseeCowboy F150F250F350 TheRainbowBoxer WellThatsSurprising craftsman30mph XJeric muddstir Wheel Crazy MSteele323 matthew sidor Trikahilux Hillbilly Homer dangeroustoys56 dylansrockinrigs tractormods CornishMorgan Tractor Man Jeff 47 posters |
MurrayMayhem Member
![TMJ's Craftsman LT1000 Conversion Thread - Page 12 Empty](https://2img.net/i/empty.gif) | Subject: Re: TMJ's Craftsman LT1000 Conversion Thread May 16th 2013, 5:33 pm | |
| - Tractor Man Jeff wrote:
- OK, that's not it than. I could unplug it and it would start to shut off, then I would plug it back in and the engine would kick back on. What else would cause this?
I kind of did the same thing, mine was kohler and I just pulled it out of the solenoid and screwed it back in, do I cut the wires off? | |
Tractor Man Jeff Moderator
![Tractor Man Jeff](https://2img.net/u/2812/37/66/46/avatars/375-11.jpg)
Age : 29 Join date : 2012-06-26 Points : 4893 Posts : 492 Location : Back in the sticks of VA
![TMJ's Craftsman LT1000 Conversion Thread - Page 12 Empty](https://2img.net/i/empty.gif) | |
Murray modder Member
![Murray modder](https://2img.net/u/2812/37/66/46/avatars/496-7.jpg)
Join date : 2012-11-23 Points : 4681 Posts : 356 Location : Somewher in Va
TheRainbowBoxer Moderator
![TheRainbowBoxer](https://2img.net/u/2812/37/66/46/avatars/326-23.jpg)
Age : 49 Join date : 2012-04-23 Points : 5581 Posts : 1091 Location : Galion, OH
![TMJ's Craftsman LT1000 Conversion Thread - Page 12 Empty](https://2img.net/i/empty.gif) | Subject: Re: TMJ's Craftsman LT1000 Conversion Thread August 18th 2013, 10:39 pm | |
| About 45 min east of richmond and 8 miles west of West Point. Come on over sometime if your in the area. Ok folks, here is the current look and a sneak peak of what to expect.![TMJ's Craftsman LT1000 Conversion Thread - Page 12 Image_zps73b992d5](https://2img.net/h/i1163.photobucket.com/albums/q554/IDIdieselnut/My%20lawn%20mower%20conversion/image_zps73b992d5.jpg) A while back, I bought a 86 honda TRX 125 for $50 bucks. It is missing some parts however, so till I get the money to get the parts, I borrowed the huge knobby rear tires for use as my new rear tires on Butch. Instead of using those no count golf cart tires, I decided to use the old rear tires on the front. Problem was, both the old set of rears and the 125's rear tires had different bolt patterns. Worse yet, the golf cart hubs also had different patterns too, so what to do? After looking at the golf cart hubs, I found I was able to make another set of four holes that would fit the old set of rear wheels.(From an 87 TRX 250x) The pics will show what I did.
![TMJ's Craftsman LT1000 Conversion Thread - Page 12 IMG_0934_zpsbfe5d729](https://2img.net/h/i1163.photobucket.com/albums/q554/IDIdieselnut/My%20lawn%20mower%20conversion/IMG_0934_zpsbfe5d729.jpg)
![TMJ's Craftsman LT1000 Conversion Thread - Page 12 IMG_0937_zps967fb1af](https://2img.net/h/i1163.photobucket.com/albums/q554/IDIdieselnut/My%20lawn%20mower%20conversion/IMG_0937_zps967fb1af.jpg)
![TMJ's Craftsman LT1000 Conversion Thread - Page 12 IMG_0938_zps2e66945d](https://2img.net/h/i1163.photobucket.com/albums/q554/IDIdieselnut/My%20lawn%20mower%20conversion/IMG_0938_zps2e66945d.jpg) Now for the back tires, IT was a matter of drilling a new set of four holes in the spindle to fit the 125 rears. Pics will explain.![TMJ's Craftsman LT1000 Conversion Thread - Page 12 IMG_0941_zps41e41e42](https://2img.net/h/i1163.photobucket.com/albums/q554/IDIdieselnut/My%20lawn%20mower%20conversion/IMG_0941_zps41e41e42.jpg)
![TMJ's Craftsman LT1000 Conversion Thread - Page 12 IMG_0942_zpsa5d03760](https://2img.net/h/i1163.photobucket.com/albums/q554/IDIdieselnut/My%20lawn%20mower%20conversion/IMG_0942_zpsa5d03760.jpg)
![TMJ's Craftsman LT1000 Conversion Thread - Page 12 IMG_0943_zps462713c1](https://2img.net/h/i1163.photobucket.com/albums/q554/IDIdieselnut/My%20lawn%20mower%20conversion/IMG_0943_zps462713c1.jpg) Now this makes a problem in itself. The rears now are sucked in while the fronts are stuck way out. I'll have to extend the rear axles a little. This will involve making supports to avoid snapping the transaxle. This will be made using two idler pulleys with a 3/4" bore. For later though. As it stands, it is drivable, but silly looking. I am having an issue getting my engine to run. Issue started with a bad float. Soldered it and it no longer leaks. Still no go. Fuel just gushed out the top of the carb. Once running, it will start bogging down with black smoke. I'll shut off the fuel and it will smooth out but will just flood out the carb upon opening the feul valve again. I know the float is working so any help will help. | |
xxXMowerdudeXxx Established Member
Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7198 Posts : 2914 Location : Ontario Canada
![TMJ's Craftsman LT1000 Conversion Thread - Page 12 Empty](https://2img.net/i/empty.gif) | Subject: Re: TMJ's Craftsman LT1000 Conversion Thread August 19th 2013, 7:21 am | |
| Looking good! Time to get a winch!
Check to make sure the float height is set correctly, and flip the carb over in your hands a few times listening and feeling to make sure the float is moving, and not hanging up. The design and placement of the gasket on these carbs has the potential to jam up the float. Trim around the hinge area with an exacto knife if necessary. Very closely inspect the fuel inlet needle and seat for trash and damage. It takes just the tiniest bit of junk to make it flood out just like you are describing. Having the fuel pump push the fuel makes a fault like that worse. You may have to replace the needle because it really can be hard to see a tiny nick or ding on it. Same goes for the seat, but it's tougher to replace. | |
![TMJ's Craftsman LT1000 Conversion Thread - Page 12 Empty](https://2img.net/i/empty.gif) | Subject: Re: TMJ's Craftsman LT1000 Conversion Thread August 19th 2013, 8:24 am | |
| Thanks doc. I've tried checking that but maybe it's still no right. I'll check on that. I have a winch well sorta. It's a big belt driven right angle gear box with crazy gear reduction. If I can get the belts there will be the kicker. | |
![TMJ's Craftsman LT1000 Conversion Thread - Page 12 Empty](https://2img.net/i/empty.gif) | Subject: Re: TMJ's Craftsman LT1000 Conversion Thread August 19th 2013, 8:29 am | |
| That'd sure be interesting. Meanwhile, there's no shame in mounting a manual, boat trailer winch or something like that, until you find something better. In fact, I think somebody here mighta just did that, and I did think of maybe doing that before I got my electric winch. When you're in a bind, any mechanical advantage you can get is a good one! Can be handy for pulling/towing things, too.
Yes- go back and recheck the fuel inlet system. Clearly, there's a problem there, ad the symptoms all point to the same thing. | |
FOSWMT Member
![FOSWMT](https://2img.net/u/2812/37/66/46/avatars/1042-88.jpg)
![TMJ's Craftsman LT1000 Conversion Thread - Page 12 Empty](https://2img.net/i/empty.gif) | Subject: Re: TMJ's Craftsman LT1000 Conversion Thread October 20th 2013, 5:02 pm | |
| Hi Jeof like the front disk on the adapters what did they come of of was looking for something similar . Looks good so far keep up the good work.
Regards
Martin | |
![TMJ's Craftsman LT1000 Conversion Thread - Page 12 Empty](https://2img.net/i/empty.gif) | Subject: Re: TMJ's Craftsman LT1000 Conversion Thread November 24th 2013, 4:46 pm | |
| Hey guys, this project is still going strong. Lack of funds have made work slow. Still trying to find a transaxle. I stumbled on a smokin deal on another set of honda ATV wheels. 4 tires and 3 aluminum rims. Two rear rims and tires, and two front tires with one bent up front rim. All tires are mint with great tread. The rears are for butch. The front tires will go on the 87 TRX 250 parts ATV that has two good front rims. That will be a future project. Also got a set of TRX 125 wheels to do stuff with.(rears are in the pics above) Pics will come later this evening. | |
Doug Site Owner
Age : 29 Join date : 2012-12-24 Points : 7659 Posts : 3044 Location : Lebanon County, PA
![TMJ's Craftsman LT1000 Conversion Thread - Page 12 Empty](https://2img.net/i/empty.gif) | Subject: Re: TMJ's Craftsman LT1000 Conversion Thread November 24th 2013, 6:32 pm | |
| JEEEEEEEEEEEEEEEEEEEEEEFFFFFFFFFFFFFFFFF!
Depending on how bad that one rim is, you might be able to fix it or run a tube. ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
Doug Site Owner
Krawler86 Member
![Krawler86](https://2img.net/u/2812/37/66/46/avatars/1298-80.png)
Join date : 2014-01-02 Points : 4034 Posts : 152 Location : PNW
![TMJ's Craftsman LT1000 Conversion Thread - Page 12 Empty](https://2img.net/i/empty.gif) | Subject: Re: TMJ's Craftsman LT1000 Conversion Thread February 3rd 2014, 12:56 pm | |
| Sorta A revive of a project that has sat for months without even a sniff about it. Thanks to xxXMowerDudeXxx, I got a new peerless trans for butch. I think it's a 901. Correct me if I'm wrong. It's got 3/4" axles. Will hopefully slip onto the front burner soon, as I'm gonna really need Butch for farm chores. As of now, still waiting. Will need to make hubs for the rear wheels. | |
1997 Murray Veteran Member
Age : 25 Join date : 2013-11-13 Points : 5326 Posts : 1311 Location : NW USA
![TMJ's Craftsman LT1000 Conversion Thread - Page 12 Empty](https://2img.net/i/empty.gif) | Subject: Re: TMJ's Craftsman LT1000 Conversion Thread February 6th 2014, 12:53 pm | |
| Awesome. Thanks for the correction Andy. The spicer Started slipping real bad. Bent shifting dogs were the culprit i believe. So i donated it to my Bro's Pedal car build. I bought the Peerless from MD to replace it. Got Butch into the garage and ready to start. I found a stick of Key way material laying around, so that problem is solved. The last hurdle to jump is the fabrication of new rear spindles. Once those are made, it's all go from there. I've got two ATVs worth of parts so I may put the 4 link suspension on the front and do direct steering. who knows. Stay tuned, Will get it done somehow. | |
