 Tires for Craftsman LT1000
82cabby
Tires for Craftsman LT1000 Empty
PostSubject: Tires for Craftsman LT1000   Tires for Craftsman LT1000 Icon_minitimeFebruary 27th 2020, 10:51 pm
Hi all,
I have an LT1000 which I need to be able to pull a trailer which, when loaded with maple sap is 500 pounds, up a bit of an incline. Turf savers with chains are NOT cutting it. They just spin and dig holes. I live in the woods and only use the tractor for hauling so protecting grass is not an issue. The current tires are 18 x 8.5 x 8. Can someone recomend a tire which will fit these stock rims that would get me maximum traction but not break the bank? I going taller would be great as long as they fit under the fenders.
Any help would be appreciated,
Dave
PostSubject: Re: Tires for Craftsman LT1000   Tires for Craftsman LT1000 Icon_minitimeFebruary 28th 2020, 8:12 am
you would get more out of locking the axle and keeping what you have, i know it is more work but I dont think tires are going to fix the problem...
82cabby
PostSubject: Re: Tires for Craftsman LT1000   Tires for Craftsman LT1000 Icon_minitimeFebruary 28th 2020, 11:08 am
Thanks for the reply. I had a reply to a previous post in a different thread that recommended against locking the axle since I have to do some fairly tight maneuvering in the woods. Here is that thread: https://www.atltf.com/t6035-need-some-help-with-craftsman-mods-new-to-this
That said, I am a complete rookie so if locking the axle would make sense then I am willing to give it a go. I would have to find another axle to try it on as I am hesitant to experiment on the original one.
PostSubject: Re: Tires for Craftsman LT1000   Tires for Craftsman LT1000 Icon_minitimeFebruary 28th 2020, 1:36 pm
Yeah if you have a lot of tight turns...
Locking would help, but like mentioned before may mess up your steering.
I have had good luck with this style of tread in the past unlocked.
TIRE LINK
Tires for Craftsman LT1000 Wp_20113
Is that the trailer you are pulling?  If so, what are the odds of getting a little taller and wider tire for it?  I see those wheelbarrow style tires digging in like anchors.
Also, slower is faster sometimes to keep traction, but i'm sure you know that.
Tires for Craftsman LT1000 Sig115PROJECTS:
Tires for Craftsman LT1000 Sig214Tires for Craftsman LT1000 Sig314
82cabby
PostSubject: Re: Tires for Craftsman LT1000   Tires for Craftsman LT1000 Icon_minitimeFebruary 28th 2020, 2:20 pm
That is one of two trailers. That one is for sap and can weigh 500lbs when full. I can probably get wider tires on it without too much trouble. I might have to change the axles. The other one I use is just a regular garden trailer for hauling firewood.
The tires on there now are 18x8.5 - 8.  Will the 18x9.5 -8 fit or will they be too wide for the rims? I am tempted to go with something like this but $70 each is pricey for me:
https://simpletire.com/otr-18-8.5r8-t10004188508-tires?stmodel=lawn-trac&stcategory=other&sttype=lawn-garden&utm_source=google&utm_medium=cpc&utm_campaign=G_Shopping_Region_01&utm_content=Other_HighProfit_RAD&utm_term=&utm_creative=383435608973&gclid=Cj0KCQiAkePyBRCEARIsAMy5SctKqd9x9Nm9CxE6iLVeYjqoyMDezVwH_cDthwztb0ZwPTQLP64KycMaAvP-EALw_wcB
These are $50 apiece but, again, I am not sure about the 9.5 width:
https://www.zoro.com/hi-run-lawngarden-tire-18x95-8-2-ply-wd1059/i/G7065125/feature-product?gclid=Cj0KCQiAkePyBRCEARIsAMy5Sct76ReE8EVc0i0KUAsHZ8qYlRfoQcn-owtqxwEbPdffYChS6LWtz_4aAi0tEALw_wcB&gclsrc=aw.ds
Thanks for your help, I appreciate it.
yeethaw
yeethaw
PostSubject: Re: Tires for Craftsman LT1000   Tires for Craftsman LT1000 Icon_minitimeFebruary 28th 2020, 2:49 pm
i have the same style of tires that mighty posted on my lt1000 with a locked diff, i was able to get the set off amazon for $50 but i cant find the link again. they work decently well except for when im in muddy clay. and as for the locked diff the difference in turning radius wasnt too bad at all except in snow
82cabby
PostSubject: Re: Tires for Craftsman LT1000   Tires for Craftsman LT1000 Icon_minitimeApril 5th 2021, 9:30 pm
I don’t mean to resurrect an older thread, but about two weeks after I posted this originally COVID shut the world down and I haven’t had a time or funds to take on the tractor again till now.
So my current question is the tires on the rear now are 18 x 8.5 x 8, How wide can I go and get the tire to seal, and also not rub?
PostSubject: Re: Tires for Craftsman LT1000   Tires for Craftsman LT1000 Icon_minitimeApril 5th 2021, 11:17 pm
I would think 9.5 and 10 width would work.
» Craftsman lt1000
» Greets - Craftsman LT1000
» WANTED: MST-206 AND a Craftsman LT1000
» Craftsman LT1000 "NellyBelle"
» TMJ's Craftsman LT1000 Conversion Thread
