| Lengthen Frame | |
dmk New Member
| Subject: Lengthen Frame March 26th 2012, 10:45 am | |
| I have an older Cub 1330 - no deck. I've installed a double seat for my boys to play around on and do yard chores, haul little trailer etc. It's got the Hydro rearend, so don't have to worry about high-speed. I'd like to lenghten it a bit, add a bed to the back, nothing crazy, just a foot, maybe 1 1/2. Do I need to weld in the new piece, or if I overlap sufficiently, will bolting it in work? I have a welder, just not good with it at all.
I won't be hauling trees with it or anything, actually live in the city, it's just a toy. | |
| Subject: Re: Lengthen Frame March 26th 2012, 7:24 pm | |
| For max saftey itd be better to weld it, but you could use grade 8 bolts and just tack it in place. Id use square tubing ( large square) to be able to support weight .
Do you have a vocational school nearby? I took some welding classes thru a local school, helped dramatically with my welding , they wernt all that much either . | |
| | | redneckrob Member
Age : 29 Join date : 2011-01-10 Points : 5115 Posts : 41 Location : Fort Worth
| Subject: Re: Lengthen Frame March 30th 2012, 9:00 pm | |
| I'd have to say do both, but remember "Bolts break, welds wont"(not entirely true, but good enough). Plus welding is an easy skill to learn, it's all about penetration! | |
| | | | | Lengthen Frame | |
