| Briggs And Stratton Formula Racing Engine | |
motorhead45102 Member
Join date : 2010-03-07 Points : 5700 Posts : 244 Location : Ohio
| Subject: Briggs And Stratton Formula Racing Engine April 25th 2010, 10:43 pm | |
| Man I would be so happy if i can get a hold of one of these. [img] [/img] but i also have a Briggs 5hp I/c block so if i wanted to have the broken piece welded back on and put dual valve springs in, and a racing head, which right now my 5hp has lots of compression, if you don't yank hard enough it will kick back and rip your hand off, but more valve spring pressure would mean faster snap back at high rpms, i wish i could also put a digital pvl ignition like this formula has, but i would have to have one that limits at a lower rpm, this formula revs up to 7,000 which hits the limiter, that is crazy high for a briggs engine, but its built to run that high. | |
| | | Guest Guest
| | | | Chunk Established Member
| | | | Webmaster Webmaster
Age : 14 Join date : 2010-02-09 Points : 5732 Posts : 332 Location : Here!
| Subject: Re: Briggs And Stratton Formula Racing Engine April 28th 2010, 10:50 pm | |
| If y have access to a lathe or able to machine parts, y can adapt any carb to a lawntractor motor - most use motorcycle or snow mobile carbs - problem with those is finding the right jets to make it run right- id like to take the carbs off my snowmobile and put em on something - ill probably sell it tho since its been in my shed at the folks place for like 6 years now. | |
| Who is online? | In total there are 23 users online :: 0 Registered, 0 Hidden and 23 Guests
