| knocking & where can i also get a engine rebuild kit for a briggs & stratton 21.5hp vtwin? | |
+3WellThatsSurprising greener179 CityRedneck 7 posters | Author | Message |
CityRedneck Member
Age : 28 Join date : 2011-08-13 Points : 5138 Posts : 241 Location : Winter Park
| | | | greener179 Member
| | | | WellThatsSurprising Member
Age : 27 Join date : 2012-04-30 Points : 5001 Posts : 407 Location : East Bethel, MN
| | | | greener179 Member
| | | | TheRainbowBoxer Moderator
Age : 49 Join date : 2012-04-23 Points : 5695 Posts : 1091 Location : Galion, OH
| | | | CityRedneck Member
Age : 54 Join date : 2010-02-10 Points : 7070 Posts : 1726 Location : Florida, USA
| Subject: Re: knocking & where can i also get a engine rebuild kit for a briggs & stratton 21.5hp vtwin? August 18th 2012, 10:38 am | |
| when you over rev a motor alot, the motor can only handle so much - more then likely its rod knock , meaning either the berings on the rod are wearing out or the rod bolts are loose - if you keep running it, itll eventually blow up- could be valve clatter also - hard to tell.
Best places to find a rebuild kit are Ebay and local tractor parts place- i imagine it wont be cheep either - a buddy of mine bot a rod, piston and rings for $50 for his single 12HP.
Personally, id buy all high performance stuff for it so it can handle more abuse- yeah its alot of money, but then itll last longer.
| | | CityRedneck Member
| | | | dked41 Member
Age : 60 Join date : 2012-01-31 Points : 4802 Posts : 141 Location : central Wisconsin
| | | | AcreFarm Member
Age : 40 Join date : 2011-11-02 Points : 4930 Posts : 208 Location : Tennessee
| | | | greener179 Member
| | | | CityRedneck Member
| | | | Sponsored content
