 Engine rebuild
Redhawke
Engine rebuild Empty
PostSubject: Engine rebuild   Engine rebuild Icon_minitimeOctober 8th 2016, 7:01 pm
I have a 14.5 HP Quite IC engine that I want to build into an off-roader. Briggs & Stratton model number 287707 Type 0224-01. Trying to find out if this engine is a good choice and what would be the best mods for rebuild. Carb, cam, and what ever else anyone can come up with. Thanks for any help. Very Happy
PostSubject: Re: Engine rebuild   Engine rebuild Icon_minitimeOctober 8th 2016, 7:30 pm
Thats one of the best to use IMO. Just a cheap Mikuni clone 28mm slider carb and a governor delete are all thats really needed. i would estimate power with those mods around 18 hp. Anyone else?
PostSubject: Re: Engine rebuild   Engine rebuild Icon_minitimeOctober 9th 2016, 8:52 am
If you wanted to modify the internals of the engine, shiming the head a bit to increase the compression and welding on extra long lobes onto the cam. If you'd prefer not to dive deep into the engine, I'd suggest maybe filing the flywheel key to advance the timing (slightly) and carb/governor removal etc.
Timrsnakess
Timrsnakess
PostSubject: Re: Engine rebuild   Engine rebuild Icon_minitimeOctober 9th 2016, 10:13 am
I have a 15hp (model# 28n707) and all I did to it was a little porting in the head and polished all of the journals and bearings. It runs good but I'm not looking for any serious power. On top of what I did you could try decking the head for some compression and a diff carb/governor
Redhawke
PostSubject: CraftsmanQuad19   Engine rebuild Icon_minitimeOctober 10th 2016, 11:17 am
Is this the carb you are referring to ? Mikuni TM Series Flat Slide Carburetor (VM28-418) - 28mm .
scratch
PostSubject: Re: Engine rebuild   Engine rebuild Icon_minitimeOctober 10th 2016, 11:29 am
That would work fine yes, but I was referring to the round slide. And the genuine Mikuni is quite expensive. A cheap knockoff is about 30 bucks on eBay and works just fine
PostSubject: Re: Engine rebuild   Engine rebuild Icon_minitimeOctober 10th 2016, 3:39 pm
You'd need to weld up a manifold for that slider carb.
I used to modify old genuine Honda 5.5 and 6.5hps for racing/rallying about in fields. The basics really are, more fuel and air in, more power out. I'd suggest right away that you pull the head and clean the carbon as that can effect performance quite badly in my experience. Another thing that hasn't been mentioned yet is a straight through exhaust. The baffles on a stock exhaust are usually pretty restrictive so if you can let the exhaust gases leave the cylinder quicker, then you'll get more power.
PostSubject: Re: Engine rebuild   Engine rebuild Icon_minitimeOctober 10th 2016, 7:50 pm
With the engine he is using, he can use the stock OEM manifold. He just needs to take a rat tail file and widen out the hols a little, not much to it.
Redhawke
PostSubject: Re: Engine rebuild   Engine rebuild Icon_minitimeOctober 11th 2016, 6:30 pm
I ordered the round slide Mikuni off ebay yesterday. I will clean the entire engine when I tear it down later this fall and will pay particular attention to the head. Now trying to find a rebuild kit for the carb. It came off a John Deer Spitfire Kohler 340. I cant seem to locate a kit for it though because I can't find the year model of the snowmobile it came off. Its a 28MM though, if any of you guys can make a suggestion on a rebuild kit please let me know. I will work on the exhaust upon rebuild as well. Thanks for all the suggestions guys, it's just what I needed. jocolor
Engine rebuild
» knocking & where can i also get a engine rebuild kit for a briggs & stratton 21.5hp vtwin?
» Honda HT-R 3009 mid engine rider engine swap
» 1977 Ford F-150 Ranger XLT(Slightly Modified) [PICTURE HEAVY]
» tranny rebuild
