 Can i put some silicone sealant where the carb meets the intake manifold?
2 posters
akcender
akcender
Can i put some silicone sealant where the carb meets the intake manifold? Empty
PostSubject: Can i put some silicone sealant where the carb meets the intake manifold?   Can i put some silicone sealant where the carb meets the intake manifold? Icon_minitimeDecember 16th 2011, 4:40 pm
can i put some silicone sealant where the carb meets the intake manifold?
AcreFarm
AcreFarm
PostSubject: Re: Can i put some silicone sealant where the carb meets the intake manifold?   Can i put some silicone sealant where the carb meets the intake manifold? Icon_minitimeDecember 16th 2011, 4:57 pm
No, silicon & fuel don't mix. Permatex makes Form-A-Gasket products or MotoSeal #29132 that's designed to be used near fuel.
It's probably cheaper just to get the correct gasket.
I've made gaskets out of thin cardboard (like a cereal box or 12-pack) with no problems. I trace & cut out the gasket, spread a thin layer of grease on both sides and use it. Works in a pinch if you need it to Wink
» New intake setup on slide carb 17.5 tecumseh
» Tecumseh hh100 carb
» 12.5 IC Flathead blowing air out through intake
» B&S Oppy Intake Valve Seals
» Backfires when brought to low idle
