 B&S Oppy Intake Valve Seals
2 posters
CosmicArkie
B&S Oppy Intake Valve Seals Empty
PostSubject: B&S Oppy Intake Valve Seals   B&S Oppy Intake Valve Seals Icon_minitimeMay 1st 2020, 11:38 am
I've got a 460777 2277 E1 pressure oiler I'm freshening up.  The gasket set didn't come with intake valve seals - parts lookup calls for 273312 that is superseded by 691891 which looks like just a flat washer in the pics I've found.
I've got seals out of the engine that look more like 692324 with spring-loaded collars, but that number is disco-ed.
What are you guys using?
TIA
PostSubject: Re: B&S Oppy Intake Valve Seals   B&S Oppy Intake Valve Seals Icon_minitimeMay 1st 2020, 5:33 pm
I looked up your engine on partstree. The valve seal you described is Part# 692036 (Superseded to 692324) I looked up 692324 and there are two available on ebay
https://www.ebay.com/itm/OEM-Briggs-Stratton-Valve-Seal-692324-Part-497212/293564885877?hash=item4459d4ab75:g:nwoAAOSwVzxeq0gj
CosmicArkie
PostSubject: Re: B&S Oppy Intake Valve Seals   B&S Oppy Intake Valve Seals Icon_minitimeMay 1st 2020, 10:15 pm
DAYUM!
I saw that listing and didn't see the (2) available....
Thanks, Carl.
» 12.5 IC Flathead blowing air out through intake
» 14.5hp Briggs wont run, gas being blown out intake?
» 18hp oppy?
» 42 c.i. oppy carb
» Can i put some silicone sealant where the carb meets the intake manifold?
