| | Heres My craftsman rider 14.5hp i/c gold ohv | |
Plyxrs Member
Age : 30 Join date : 2011-11-26 Points : 4766 Posts : 26 Location : Indiana
Age : 53 Join date : 2010-02-10 Points : 7042 Posts : 1726 Location : Florida, USA
| Subject: Re: Heres My craftsman rider 14.5hp i/c gold ohv November 27th 2011, 6:05 am | |
| You can weld and reinforce those front bars - they keep the front of the trans from flipping up tward the top of the chassis.
Ive said it before - its not possible to make a stock tractor faster w/o proper mods , unless you enjoy expensive trips to the ER or possible morgue.
This is speaking from 2 prior builds that failed miserably - yeah i built 2 tractors, nearly bone stock and pushed them past 20mph - the first ( craftsman) broke its trans while taking off ( i did nothing to prep it- no brakes, no trans prep ) - luck was on my side that it didnt happen at full speed. Second one( murray) was way faster, but was way too unstable to push past 30mph ( was capable of higher speeds) - in the couple years it was together i nearly crashed it a dozen times, flipped it more then once - i had enough and took it apart- wasnt worth killing myself over going faster.
My 3rd one was a total improvement ( MTD) - i bolted the seat to the chassis, raised the front axle to the top of the chassis ( bolted solid) lower profile tires in back and had way better brakes - it handled tons better then the original two ever had. I couldnt get any faster speed from it, so im redoing that one, in its final setup itll have larger tires, lower stance ( 4" ride height), twin cylender, 1" straight axle - not sure wether ill use a peerless 700 or a RAGB, custom built spindles , direct steering and disc brakes.
When i put the hammer down - itll handle like i want, stop when i need to and generally be a whole lot safer then anything prior.
My goal is to use a stock twin cylender motor, using the governer to push it to near 50mph , which should possible , considering its the same motor from my murray. | |
| | | CityRedneck Member
Age : 28 Join date : 2011-08-13 Points : 5110 Posts : 241 Location : Winter Park
| | | | CityRedneck Member
| Subject: Re: Heres My craftsman rider 14.5hp i/c gold ohv November 28th 2011, 12:41 am | |
| Usually you dont want to go smaller then 3" on the back- the belt wont have enough 'wrap' around it - itll work breifly , but just eat up belts because it slips too much.
Alot has to do with other factors also - tire size, gear ratios - my murray had a briggs opposed twin 18.5HP , 6" motor pulley , 3" trans pulley, 6 speed shift on the fly trans and ran 4 8" wheels - i was hitting around 30mph in 3rd gear. If i had it set up better , i wouldve seen just how fast it wouldve gone.
Originally with stock tires, same pulleys and the stock 14.5HP OHV motor - it wouldnt go past 15-20mph in 6th - motor just didnt have the powerband, the twin has power to spare .
Id like to change the motor pulley size to at least 7-8" and see what that nets.
| | | Plyxrs Member
| Subject: Re: Heres My craftsman rider 14.5hp i/c gold ohv November 28th 2011, 11:43 am | |
| Thanks guys! and thankyou for that info! i dont plan to act crazy on it at all, just want some more speed, so i plan to just leave the front pulley alone which i think is a 6"? im not positive and make the back a 4" but i need to figure out what size belt is needed, right now i got the motor off and all electrical, doing toggle switch for kill & to turn on the carb solenoid, & push button start of course, i need to get that welded back up soon as well, i also would like to try to mount the battery under the gas tank inside the steering column area beind the motor - not sure if it will work tho, but i got the engine off at the moment so i can tighten up all bolts and make the steering stronger because it tends to slip somehow, i think its be cause the steering colume is missing a bolt which allows it to move when i turn to much. but once again thank you | |
| | | CraftsMAN Member
Age : 38 Join date : 2010-06-01 Points : 5753 Posts : 364 Location : NY
| Subject: Re: Heres My craftsman rider 14.5hp i/c gold ohv November 29th 2011, 11:22 pm | |
| Say on my Dynamark I have a stock pulley in the front and a 3-1'2 on the back. Now if I went with a bigger pulley in the front would that give me more torque? The tractor wont go up a hill in hi 1st gear// lol | |
| | | CraftsMAN Member
| Subject: Re: Heres My craftsman rider 14.5hp i/c gold ohv November 29th 2011, 11:30 pm | |
| Oh and if you are going to swap out the front pulley how do you go about doing so? My drive pulley is attached to the mower deck pulley. Do I cut and weld? | |
| | | Plyxrs Member
| | | | CraftsMAN Member
| | | | Plyxrs Member
| Subject: Re: Heres My craftsman rider 14.5hp i/c gold ohv December 5th 2011, 9:22 am | |
| So far no they do not, and thank you, it is pretty cool huh? and now i can go thru deep water with out the exhaust hittin water and killin the engine woohoo | |
| | | Plyxrs Member
| Subject: Re: Heres My craftsman rider 14.5hp i/c gold ohv December 6th 2011, 1:10 am | |
| Youll want to add a snorkel for your carb also - water will just pour right in and kill the motor - you might also want to use dielectric lube on the electrical connections or seal them - eventually water will get in and youll have electrical issues. | |
| | | Plyxrs Member
| Subject: Re: Heres My craftsman rider 14.5hp i/c gold ohv December 6th 2011, 1:31 am | |
| she wont be that deep, but thankyou for the information, the exhaust was gonna go straight out the side but decided that would look cooler, i just go thru water that is maybe just hardly as deep as my front wheels, the exhaust used to sit in the front and was super low so thats why i re-done it, and does anyone know how i can do my belt so she wont slip in the water as bad? | |
| Who is online? | In total there are 32 users online :: 1 Registered, 0 Hidden and 31 Guests ranch king pro 08Most users ever online was 412 on January 7th 2023, 6:59 am |
