I do not know exactly which lamp is getting smacked by limbs. Maybe this would fit?
Sweet tractor, I would be wearing the tires off of it!
It’s the ones mounted on the loader mast/the round sealed beams. Going to switch to some 3” round flat backs mounted behind the brush guard.
And thank you! She sure is easy on my eyes.
Mounted some grab hooks on the bucket, upgraded to flanged hardware and heavy grade spacer washers on the stub axle bolts. Was told by a few people those are needed for loader work (the washers) to prevent axle tube cracking. Mine is still cherry so an ounce of prevention beats a pound of cure. (That and new hardware looks nice )
New lettering came in and got mounted, same with the billet shift knobs. Humina humina Wahooey! Also painted the gauge needles, and removed the flaking paint from the instrument cluster and went to a brushed aluminum polish which I like.
Rear work lights wired in finally. Debating on a second pair on the fenders- one facing down towards the 3pt and one point off to the 5 o clock position for running balers and haybines and the like. Would like to try putting hay in with this ol girl someday, but not soon probably.
Did check the trans oil and it’s milky again… going to change it again. Wondering if going from the universal fluid to 90 wt could quiet some of the gear or bearing whine in the trans, but I wanna read up on that and make sure the rear axle sump and transmission sumps aren’t conjoined, as 90wt in the hydraulics is not something I want and this tractor has wet brakes so additives are mandatory.
May just get an extra pail and do the rear end while I’m at it, it was clean when I got the tractor so I didn’t bother but it certainly wouldn’t hurt to do.
I bought a v plow to mount to the bucket for snow removal and a set of snow chains.
Thinking down the road I want to install a splitter plate under the remote valve which would allow me to keep the original remote, maintain seat suspension travel clearance and I could also get a top and tilt kit. Can’t remember the number off the top of my head but I found a Gannon cylinder clone that will cross over. Tops are universal so that’s easy.
Kinda ironic I’m building a nearly 60 year old tractor to have more features than most new ones in this size range. Cept the AC… but a 445 4x4 with a sims cab is on my bucket list, to get air conditioning, R14 style tires, custom gauge cluster, single stick loader conversion with SSQA and 3rd function. Ideally this one can do all the “fun” jobs and the cab tractor can do the stuff that’s sweaty and nasty.
JB_4x4 Member
Age : 63 Join date : 2023-04-25 Points : 847 Posts : 256 Location : Atlanta GA
One of the benefits of an enclosed A/C cab in Georgia is so when you run over a yellow jacket nest doing field work, you do not end up a pin cushion. Though probably not a problem in any place that needs a snow plow.
As I used to tell people when I was a mechanic., fluid is cheap, hardware is not. Never mind single sourced hardware, made in low quantities over 10 years old. It is a beauty for sure.
Join date : 2021-01-15 Points : 2853 Posts : 1340 Location : Upstate New York
Looks like next year a double split or at the very least a good inspection of all the bearings and shafts is in order. Changed the transmission oil today, and a few metal flakes on the plug (not magnetic so they’re dispersed through the trans). Combined with the whining in second and 6th gear I suspect I have a worn bearing or a worn countershaft.
The oil looked like liquid rust. Absolutely disgusting, and pretty concerning considering this was done maybe 14 months/ 40 hours ago. Maybe part of that is the residual sludge from the first change, which was like milk. For the time being I’m going to limit my use of second and keep an ear on it, it should get through to next year OK. Sounds normal in the other gears so I highly doubt I’ll be adding any abnormal wear.
Peering into the fill port with a flashlight, I didn’t see any chipped or broken gear teeth on the rear half/what I can see, so I’m hopeful. Depending on how pricey a rebuild is I may swap in a dual power trans so I can have the creeper gear. Definitely would be nice for running tillers and the like.
