Hi names Jeff, Thank you for the ad. i look forward to meet other like minded lawn tractor enthusiast.
my current tractor is an craftsman lt1000, originally swapped some atv spindles onto the front and swapped the atv tires/rims over from a Suzuki lt125, fabbed up a custom hitch in the rear and fitted with led lights. the motor was de-governed & outfitted with a mukini carb & a tach. outfitted the tractor with a foot throttle made from a bicycle brake handle.
its currently down with a blown motor and has since been toren down farther to pull a few parts off for other tractors, but it will be coming back to life soon. i have a build planned that i will be announcing soon & planning to enter the build off competition
Welcome to the forum and cool tractor! I look forward to seeing more!
To follow up on what @Nevadablue said, you entered your address where you put the name of your channel, the address goes in the "contact field" in the next section down.
here are a couple shots when is was running
Welcome to the show man, looks like you got a pretty sweet tractor, looking forward to seeing more of this rig!
DempseySolutions likes this post
@Nevadablue thanks, she is a great helper and a even better encourager to go faster lol. she is so much like me it scares the wife sometimes,
as far as the atv spindles. it was pretty straight forward i cut the factory lawn tractor spindles off and then cut the atv spindles off and welded them to the lawn tractor steering knuckles
