| Run an FNR transaxle with the pulley vertical? | |
Nevadablue Established Member
Join date : 2021-07-01 Points : 2197 Posts : 854 Location : Nevada
| Subject: Run an FNR transaxle with the pulley vertical? March 7th 2022, 8:57 pm | |
| Will it work? I have several axles and now an apparently good 125 cc engine out of a chinese ATV. I have looked at the diagrams of the FNR innards and it appears that if it was turned 90 degrees, putting the input shaft horizontal and at the top, everything would still get lubed and it should work. Ideas? I could put a sprocket on the input shaft and mount the engine in the back of some contraption and maybe have fun with is.
| | | | RCG Member
2016 Build-Off Finalist
| | | | Sponsored content
| Who is online? | In total there are 39 users online :: 0 Registered, 0 Hidden and 39 Guests
