 Remove a stuck transaxle pulley in less then 5 minutes
RCG
RCG
2016 Build-Off Finalist
Remove a stuck transaxle pulley in less then 5 minutes Empty
PostSubject: Remove a stuck transaxle pulley in less then 5 minutes   Remove a stuck transaxle pulley in less then 5 minutes Icon_minitimeMay 3rd 2013, 9:20 am
Have done over 50 pulley removals this way over the years with only 3 or 4 not working out.
Quick clarification sense people seem to not get it from the video you are ONLY heating the pulley not the shaft. The shaft bearing will be fine unless you heat it wrong.
http://www.Mudmower.com
PostSubject: Re: Remove a stuck transaxle pulley in less then 5 minutes   Remove a stuck transaxle pulley in less then 5 minutes Icon_minitimeMay 3rd 2013, 3:37 pm
Sweet, thanks.
RCG
RCG
PostSubject: Re: Remove a stuck transaxle pulley in less then 5 minutes   Remove a stuck transaxle pulley in less then 5 minutes Icon_minitimeMay 3rd 2013, 4:05 pm
Your welcome I get the question a lot in email and on my facebook group so I figured it would help people here to
PostSubject: Re: Remove a stuck transaxle pulley in less then 5 minutes   Remove a stuck transaxle pulley in less then 5 minutes Icon_minitimeMay 3rd 2013, 5:22 pm
Funny, I'm just about to remove my first pulley ever, and it was rusted similar to your, good luck I waited for your vid.
PostSubject: Re: Remove a stuck transaxle pulley in less then 5 minutes   Remove a stuck transaxle pulley in less then 5 minutes Icon_minitimeMay 5th 2013, 9:15 am
Excellent tips, and very similar to my own methods. Thanks for posting it. If I may add- I would suggest (especially for newbs) to use a brass drift or similar softer metal for the punch, and avoid striking the shaft directly with the hammer. Some folks might get all Superman on it, and the next thing you know, the end of the shaft is mushroomed, mangled, or otherwise FUBAR.
RCG
RCG
PostSubject: Re: Remove a stuck transaxle pulley in less then 5 minutes   Remove a stuck transaxle pulley in less then 5 minutes Icon_minitimeMay 5th 2013, 9:19 am
Well said Doc Sprocket
» How do I remove a stuck Transaxle Pulley?
» transaxle stuck in third gear
» How to: remove surface rusted transaxle/gearbox gears
» Sheared the keyways side ways on my transaxle and shifter stuck
» Stuck Pulley
