| Stuck Pulley | |
Jonny Briggs New Member
| Subject: Stuck Pulley January 29th 2013, 2:47 pm | |
| How do I get the pulley off my BnS 11hp engine?
I have made a jig to bolt into the 3 bolt holes and run a smaller bolt with a trapped nut (like a hub puller) but that hasn't worked.
Don't want to heat it because it damages the oil seal.
Any ideas?
Jonny | |
| | | Doug Site Owner
Age : 29 Join date : 2012-12-24 Points : 7784 Posts : 3047 Location : Lebanon County, PA
| Subject: Re: Stuck Pulley January 29th 2013, 2:59 pm | |
| If youre not willing to use heat youll need to cut it. A puller should have taken it off. Heat is your number one friend.
You can also try PBlaster by soaking the top and bottom of the pulley in it for a few days on end, then trying your puller again.
But really you want to use some torches and a puller. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| | | Chopperhed Moderator
Age : 58 Join date : 2012-10-14 Points : 5256 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
| Subject: Re: Stuck Pulley January 29th 2013, 4:02 pm | |
| The trick is to heat the pulley by itself. Avoid heating the shaft. | |
| | | CornishMorgan Member
| Subject: Re: Stuck Pulley January 29th 2013, 4:23 pm | |
| Is the pulley a dual stacked pulley, upper on drives the gearbox, lower pulley drives the cutting deck?
I just took the nut out from the centre, sprayed a load of WD40 on shaft and pulley, i then just ran the engine for a couple of minute and drove it up and down the road. I just took the belt off and the pulley dropped right out along with key. | |
| | | | | Stuck Pulley | |
| Who is online? | In total there are 85 users online :: 0 Registered, 0 Hidden and 85 Guests
