 Sheared the keyways side ways on my transaxle and shifter stuck
Mark288
Mark288
Sheared the keyways side ways on my transaxle and shifter stuck Empty
PostSubject: Sheared the keyways side ways on my transaxle and shifter stuck   Sheared the keyways side ways on my transaxle and shifter stuck Icon_minitimeFebruary 25th 2014, 11:39 pm
Hey guys i got a 6spd spicer 4360 or somethen like tht i like the transmission but my mud tractor has been sitting since its winter and im snowmobiling not tractoring but i started it and my shifter is stuck. It wont shift unless u use 2 hands and u can pull the whole tractor sideways the shifter is locked so hard..i know i need to take the tranny apart to adjust and grease the shifter keys and that little ball bearing thing but the problem is i have to take my 27" atv tires off to get it off and my keyways are sheared like they wedged themselves completly in on a angle between the rim and axle and the rim wont budge on or off...what should/can i do about that? Thanks
PostSubject: Re: Sheared the keyways side ways on my transaxle and shifter stuck   Sheared the keyways side ways on my transaxle and shifter stuck Icon_minitimeFebruary 26th 2014, 2:38 am
flip it on it's side and remove the trans with the tires still on it. a quick run to anywhere that has a press is your best bet. It's that, or cut the rim hubs and replace the rims. 27 inch tires are a LOT to ask from a small keyway... maybe while you have it out you can cut the shaft for a bigger key (rims will need the same key cut in the hub.)
Ideally, you would have shaft and hubs splined.
PostSubject: Re: Sheared the keyways side ways on my transaxle and shifter stuck   Sheared the keyways side ways on my transaxle and shifter stuck Icon_minitimeFebruary 26th 2014, 6:36 am
Was your shifter like that when you parked it? If not, one of two things has occurred: Water ingress turned to ice and she's frozen, or rust got the better of things and jammed it up that way. You could try putting a halogen lamp underneath it for a few hours to see if you can defrost it...
Moose
Moose
PostSubject: Re: Sheared the keyways side ways on my transaxle and shifter stuck   Sheared the keyways side ways on my transaxle and shifter stuck Icon_minitimeFebruary 26th 2014, 9:51 am
ditto on the splined thing most of your heavy duty tractors have splined axles some are splined and keyed lol
» Stuck Shifter
» transaxle stuck in third gear
» Transaxle seems stuck closed...
» How do I remove a stuck Transaxle Pulley?
» Remove a stuck transaxle pulley in less then 5 minutes
