| Stuck Shifter | |
dylansrockinrigs Member
Age : 25 Join date : 2012-02-28 Points : 5038 Posts : 306 Location : Silk Hope N.C.
| Subject: Stuck Shifter July 7th 2013, 7:09 pm | |
| I've got a foote transmission from a craftsman that I'm using on my current build and the shifter is very difficult to move is there anyway I can fix this? My neighbors Murray is the same way except he has a 5 speed | |
| | | Guest Guest
| Subject: Re: Stuck Shifter July 7th 2013, 7:58 pm | |
| I would crack the case open and see if the shift fork is gummed up with crud or rust. Assuming it is, a good soak in diesel or PB blaster will help a ton. Clean everything up and regrease. Check your bushings around the shifter for the same. Whenever I get a rider with a stuck shifter as you describe it, that's the problem 9 times out of 10. Might be, although less likely something broken and jammed up against the shift fork or pin. |
| | | goesman Member
Age : 45 Join date : 2012-01-18 Points : 4853 Posts : 119 Location : Salem, Mo.
| Subject: Re: Stuck Shifter July 7th 2013, 8:33 pm | |
| I have 6 speed trans that is the same way. It came out of the SS Craftsman. I have thought about pulling it apart some day to figure out the problem, just in case i want to use it on another build. | |
| Subject: Re: Stuck Shifter July 7th 2013, 9:58 pm | |
| It was working a month ago when i tested it, it hasnt been uses in years | |
| | | Guest Guest
| Subject: Re: Stuck Shifter July 7th 2013, 11:03 pm | |
| - dylansrockinrigs wrote:
- It was working a month ago when i tested it, it hasnt been uses in years
all the more reason to crack it open and check it out, no? |
| | | | | Stuck Shifter | |
| Who is online? | In total there are 94 users online :: 0 Registered, 0 Hidden and 94 Guests
