| Shifter broke off, how do I fix? | |
13mudman13 Member
Age : 26 Join date : 2012-09-20 Points : 4535 Posts : 67 Location : Wirt County, West BygodVirginia
| Subject: Shifter broke off, how do I fix? September 20th 2012, 2:53 pm | |
| I have a craftsman lt 1000 and it has a dan spicer transmission and when i was romping yesturday i went to shift and the shifter broke clean off!!!! What do i do? | |
| | | 13mudman13 Member
| Subject: Re: Shifter broke off, how do I fix? September 20th 2012, 9:28 pm | |
| Haha omay well let me try to explAin it right where the shifter bolts underneath the right side of the seat on the frame is where it broke off | |
| | | matthew sidor Member
Age : 30 Join date : 2012-04-13 Points : 4785 Posts : 184 Location : Montesano, Washington
| | | | 13mudman13 Member
| Subject: Re: Shifter broke off, how do I fix? September 20th 2012, 10:29 pm | |
| Like that one you just showed
and since u say ur good with craftsmans uhmmm when i romp even if my.belt is tight amd i have a belt tensnier on my belt comes off what do i do??? | |
Age : 45 Join date : 2010-06-28 Points : 5800 Posts : 511 Location : Southern WV
| Subject: Re: Shifter broke off, how do I fix? September 21st 2012, 12:55 am | |
| Did you remove the belt keepers, the little bolt like things that keep the belt on each pulley? If you change the pulley sizes you have to reposition those also. | |
Age : 49 Join date : 2012-04-23 Points : 5695 Posts : 1091 Location : Galion, OH
| Subject: Re: Shifter broke off, how do I fix? September 21st 2012, 8:15 am | |
| It took us forever to figure out the best way to keep belts on... check the build in my sig and you can see what we came up with. | |
| | | | 13mudman13 Member
| Subject: Re: Shifter broke off, how do I fix? October 4th 2012, 4:08 pm | |
| weld it back on or find another lt1000 or mower with the same shifting system. alot of the new mowers have the same shifting sytem so it shouldn't be that hard to find, or you can buy one. theres a ton of options you can go with | |
| Who is online? | In total there are 10 users online :: 0 Registered, 0 Hidden and 10 Guests
