 broke my extened axles
offroadredneck
offroadredneck
broke my extened axles Empty
PostSubject: broke my extened axles   broke my extened axles Icon_minitimeThu Jan 03, 2013 4:57 pm
I recently finished my racing lawnmower that I extended the axles on but I went for a test drive and after hitting lots of bumps I noticed my weld broke and my axle wasnt strait any more. What is an easy way to re aline it?
gearheadmike
gearheadmike
PostSubject: Re: broke my extened axles   broke my extened axles Icon_minitimeThu Jan 03, 2013 5:01 pm
you mean the front spindle? like with a bolt welded on the end?
offroadredneck
offroadredneck
PostSubject: Re: broke my extened axles   broke my extened axles Icon_minitimeThu Jan 03, 2013 6:02 pm
No the rear
Chopperhed
Chopperhed
PostSubject: Re: broke my extened axles   broke my extened axles Icon_minitimeThu Jan 03, 2013 6:20 pm
we'll be needing some pics
offroadredneck
offroadredneck
PostSubject: Re: broke my extened axles   broke my extened axles Icon_minitimeThu Jan 03, 2013 6:27 pm
Ill put some on later tonight
offroadredneck
offroadredneck
PostSubject: Re: broke my extened axles   broke my extened axles Icon_minitimeFri Jan 04, 2013 9:30 pm
I couldnt get the pics to post but I got it fixed
PostSubject: Re: broke my extened axles   broke my extened axles Icon_minitimeSat Jan 05, 2013 3:37 am
Its best to have a one piece rear axle - mainly for strength, balance and no weak points - plus if it was welded off a bit itll be all wobbly.
If it needs to be extended- id run another piece of heavier pipe across the whole axle ( cept where the tire mounts) , drilling holes in the sleeve to plug weld it - it still wont be as strong as a single piece, but will hold up better.
offroadredneck
offroadredneck
PostSubject: Re: broke my extened axles   broke my extened axles Icon_minitimeSun Jan 06, 2013 12:12 pm
Ok ill try that. I tried to post a pic but my phone wouldnt let me.
» MTD axles in a Peerless
» New guy, first Off Road/ Utility tractor build.
» yay! broke my 1st trans!
» Shifter broke off, how do I fix?
» Hydro trans broke
