| yay! broke my 1st trans! | |
crafsmankiller Member
Age : 27 Join date : 2012-10-18 Points : 4893 Posts : 412 Location : livingston texas
| Subject: yay! broke my 1st trans! March 30th 2015, 7:50 am | |
| This is a story for the ages right here... On my craftsman i have a mst 206. I was yankin on a concrete culvert, f-r f-r about 20 times. After the second time it started grindin and i was like "i f im gonna break it im gonna f*** it up" So i kept slammin it f-r until the culvert was pulled out of the way.. now itll move in 1st -3rd gear and grinds horribly when driving and skips and grinds in any higher gear. Reverse still works fine tho.. i cracked it open yesterday and nothings stripped, the shift keys look almost new. The only thing thay looked bad was the input gear and the bevel gear that it meshes with. They look and feel sharp on the edges and they look like they were skipping
The only thing i can think of is the input shaft lifting up and skipping under load...
I still need yalls ideas about this. | |
| | | Doc Sprocket Site VIP
| Subject: Re: yay! broke my 1st trans! March 30th 2015, 8:11 am | |
| Very possible. With case assembled, see if you can raise/lower the input shaft.
Other than that, go over everything very carefully, also looking for stripped splines. | |
| Subject: Re: yay! broke my 1st trans! March 30th 2015, 8:23 am | |
| The input shaft has always moved up and down about 1/4 - 1/2 in. I looked real close and nothing was stripped or chipped. Im goin to try putting washers between the input gear and the case to try to prevent it from moving up and down. | |
| Subject: Re: yay! broke my 1st trans! March 30th 2015, 9:48 am | |
| I know it shouldnt be like that, but its always been that way and it hasnt ever skipped or anything,, sooo yeah.. im shimming it | |
| Subject: Re: yay! broke my 1st trans! March 30th 2015, 3:18 pm | |
| Your supposed to just drive hard and break stuff, not purposely abuse the equipment! Yeah, maybe just shim it up some and see how it goes. Pictures! | |
| Subject: Re: yay! broke my 1st trans! March 31st 2015, 11:38 am | |
| Lol. I dont abuse my equipment, i vigorously test it. But yeah i do abuse my stuff sometimes... but at least i had fun doin it.
Back on topic, i used a peice of pvc pipe to shim the shaft as tight as possible, it now moves less than 1/8th in. I used pvc so if it doesnt get lubed enough up there it wont sieze or score the casee.. time will tell if it even works or not. Im puttin back in my mower this evening and hopefully i 'fixed' it.. maybe just maybe itll work. | |
| Subject: Re: yay! broke my 1st trans! March 31st 2015, 11:43 am | |
| And while i had it open i took the reverse chain out b/c it was really.loose and draggin on the case, that and it kept grabbin reverse wheile it was sittin in neutral. Itd be idling in nuetral and itd just take off in reverse and id have to chase it down.. so i fixed that problem | |
| | | willysjeepmb Member
Age : 29 Join date : 2014-11-23 Points : 3768 Posts : 101 Location : Elora, Tn
| Subject: Re: yay! broke my 1st trans! April 6th 2015, 11:02 pm | |
| - crafsmankiller wrote:
- And while i had it open i took the reverse chain out b/c it was really.loose and draggin on the case, that and it kept grabbin reverse wheile it was sittin in neutral. Itd be idling in nuetral and itd just take off in reverse and id have to chase it down.. so i fixed that problem
hahahaha. Mine does that too, but it was just linkage needed adjusting. | |
| | | 802 Customs Member
Age : 25 Join date : 2015-01-08 Points : 3758 Posts : 146 Location : Vermont
| Subject: Re: yay! broke my 1st trans! April 7th 2015, 8:25 pm | |
| Ummm no its not.If your talking about the snap ring outside the trans, it not there. But everything internal is there. Today i did a couple burnouts and guess what.. same thing happened again.. grindin and skippin. Since i have to open it up again im going to do it right and use washers instead of pvc. | |
| Subject: Re: yay! broke my 1st trans! April 9th 2015, 1:14 pm | |
| So yesterday i pulled it out and used a nice, big thick washer to shim it. Now its the tightest its ever been. I was going to test drive it but my fuel pump died.
So yep, gotta fix my fuel pump now then i can test it good | |
| | | 802 Customs Member
| Subject: Re: yay! broke my 1st trans! April 10th 2015, 7:33 am | |
| If you saw my pully arrangment youd understand why i dont have one.lol. On a good note, i soaked my fuel pump gaskets in gas and it works again.
Anyways, the snap ring stops the shaft from moving down and my problem was it moving up, | |
| Who is online? | In total there are 81 users online :: 0 Registered, 0 Hidden and 81 Guests
