 LOTS OF PROGRESS
craftsman30mph
craftsman30mph
LOTS OF PROGRESS Empty
PostSubject: LOTS OF PROGRESS   LOTS OF PROGRESS Icon_minitimeOctober 1st 2011, 7:19 pm
well I worked on the monster mower today and got quite a bit done I got my drop shaft welded in for the the lift and the idlers on the back to keep the belt away from the shifter, hooked up my gas pedal, now all I have left is the starter AGAIN, and the breather stuff and wiring then she's pretty much done!!! CAN'T WAIT!!! heres some pics of the progress
LOTS OF PROGRESS PA010326
LOTS OF PROGRESS PA010325
LOTS OF PROGRESS PA010324
LOTS OF PROGRESS PA010323
LOTS OF PROGRESS PA010322
Now all I need is a 3.5 inch pully for the bottom of my drop shaft to finish the lift
PostSubject: Re: LOTS OF PROGRESS   LOTS OF PROGRESS Icon_minitimeOctober 2nd 2011, 3:30 pm
You are hooking up some kind of brake i hope? With the combination of pulley sizes and tire size that will go pretty fast. Id mount belt retainers around the pulleys, or youll be crawling underneath to put the belts on continuously....
With my ATV rims- i dont want to weld them to my hommade hubs ( cut down tractor rims) - in case i come across another set of ATV wheels, plus will be easy to change tires if needed - i plan on drilling and welding bolts to the tractor rims thru the stock ATV bolt holes .
craftsman30mph
craftsman30mph
PostSubject: Re: LOTS OF PROGRESS   LOTS OF PROGRESS Icon_minitimeOctober 3rd 2011, 1:05 am
yeah I'm going to hook up brakes just the stock brakes I just have to make a linkage and then I am going to make it a handbrake with the mower dack lift thing because i have a gas pedal on one side and the clutch on the other...
dirtybird
dirtybird
PostSubject: Re: LOTS OF PROGRESS   LOTS OF PROGRESS Icon_minitimeOctober 3rd 2011, 11:14 am
that tractor is insane!! love it!!
craftsman30mph
craftsman30mph
PostSubject: Re: LOTS OF PROGRESS   LOTS OF PROGRESS Icon_minitimeOctober 3rd 2011, 1:04 pm
thanks man, yours is looking sweet too!!
LOTS OF PROGRESS
» Need Some Help With Lots Of Projects
» Craftsman LT1000 Mudder
» lots of mud and broken parts
» crastsman on 33in supper swampers lots of pics and mods
» 12hp Craftsman II build ♦lots of pic's♦
