 12hp Craftsman II build ♦lots of pic's♦
5 posters
TravisMo
TravisMo
12hp Craftsman II build  ♦lots of pic's♦ Empty
PostSubject: 12hp Craftsman II build ♦lots of pic's♦   12hp Craftsman II build  ♦lots of pic's♦ Icon_minitimeMay 15th 2012, 12:51 am
ok so i got a old craftsman from a buddy of mine because iv been wanting to build a mower to do the tasks of a atv. i do alot of hunting and all around here is mainly mud. i wana build something to drag deer out of the woods and to just have fun on...this is my first welding/fabrication project so dont hate haha here we go
12hp Craftsman II build  ♦lots of pic's♦ 2012-05-11221736
12hp Craftsman II build  ♦lots of pic's♦ 2012-05-11230420
got the fenders, hood, transaxle, and all of the goodies from the deck setup
12hp Craftsman II build  ♦lots of pic's♦ 2012-05-13143820
12hp Craftsman II build  ♦lots of pic's♦ 2012-05-13153042
All stripped down and cleaned it up with some gunk
12hp Craftsman II build  ♦lots of pic's♦ 2012-05-13153141
12hp Craftsman II build  ♦lots of pic's♦ 2012-05-13155405
12hp Craftsman II build  ♦lots of pic's♦ 2012-05-13174045
notched out the c- channel so that the factory transaxle mounts can be welding on to it.
12hp Craftsman II build  ♦lots of pic's♦ 2012-05-13174430
12hp Craftsman II build  ♦lots of pic's♦ 2012-05-13181114
i dont think this is too bad for my first actual welding
12hp Craftsman II build  ♦lots of pic's♦ 2012-05-13185438
mocking up one side, this c-channel is some hard shit!
12hp Craftsman II build  ♦lots of pic's♦ 2012-05-13201348
12hp Craftsman II build  ♦lots of pic's♦ 2012-05-13201358
this is all i could get done before it got too dark. got it all welded up and its definitely rigid!
TravisMo
TravisMo
PostSubject: Re: 12hp Craftsman II build ♦lots of pic's♦   12hp Craftsman II build  ♦lots of pic's♦ Icon_minitimeMay 15th 2012, 1:02 am
Im not too sure on how i want to lift the front end. i want to keep the articulation in the front but im not sure how i want to drop it. the c channel was cut at 12" long and notched it out so the mower is actually sitting 9 inches above factory ride height. should i drop the front just as much? it will end up with atv tires most likely since only one tire that's on it holds air.
got some more work done this afternoon. cut up some angle iron and made some torsion bars. i think they came out pretty good once i notched it out and welded it across the whole back lift block so it should definately hold up the abuse. im gonna get the other side done tomorrow after work.
12hp Craftsman II build  ♦lots of pic's♦ 2012-05-14173553
12hp Craftsman II build  ♦lots of pic's♦ 2012-05-14173725
12hp Craftsman II build  ♦lots of pic's♦ 2012-05-14182548
12hp Craftsman II build  ♦lots of pic's♦ 2012-05-14184037
12hp Craftsman II build  ♦lots of pic's♦ 2012-05-14184048
12hp Craftsman II build  ♦lots of pic's♦ 2012-05-14184103
PostSubject: Re: 12hp Craftsman II build ♦lots of pic's♦   12hp Craftsman II build  ♦lots of pic's♦ Icon_minitimeMay 15th 2012, 9:25 am
I'd be tempted to cut the front axle off the frame to lower it.
TravisMo
TravisMo
PostSubject: Re: 12hp Craftsman II build ♦lots of pic's♦   12hp Craftsman II build  ♦lots of pic's♦ Icon_minitimeMay 15th 2012, 10:32 am
what do you mean? the axle have a center pivot point. im thinking about just dropping that center point down then adding some sort of limiting straps so it doesn't flex too much if you gte what i mean
PostSubject: Re: 12hp Craftsman II build ♦lots of pic's♦   12hp Craftsman II build  ♦lots of pic's♦ Icon_minitimeMay 15th 2012, 1:21 pm
I'd cut the entire front of the frame off, and lower it, and weld in place. That way you still have a stock mounting for the axle, just lower.
TravisMo
TravisMo
PostSubject: Re: 12hp Craftsman II build ♦lots of pic's♦   12hp Craftsman II build  ♦lots of pic's♦ Icon_minitimeMay 16th 2012, 7:36 pm
could you send me a link or a pic of what your talkin about? i dont really understand what you mean
PostSubject: Re: 12hp Craftsman II build ♦lots of pic's♦   12hp Craftsman II build  ♦lots of pic's♦ Icon_minitimeMay 17th 2012, 1:27 pm
My guess is, Stretch means something like this.
12hp Craftsman II build  ♦lots of pic's♦ Frame_10
However you attach the frame after that would be up to you.
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
PostSubject: Re: 12hp Craftsman II build ♦lots of pic's♦   12hp Craftsman II build  ♦lots of pic's♦ Icon_minitimeMay 17th 2012, 9:18 pm
Thanks Dan. I could not think of a different way to say it. And you are much handier with the paint program.
redzz02
redzz02
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
PostSubject: Re: 12hp Craftsman II build ♦lots of pic's♦   12hp Craftsman II build  ♦lots of pic's♦ Icon_minitimeMay 17th 2012, 9:35 pm
hey if you want front suspension check my monster on youtube on redzz02, also check under the builds section under monster mower if you do end up going suspension route ill answer all your questions
TravisMo
TravisMo
PostSubject: Re: 12hp Craftsman II build ♦lots of pic's♦   12hp Craftsman II build  ♦lots of pic's♦ Icon_minitimeMay 21st 2012, 1:28 am
thanks for the diagram. thats what i thought you ment but i wasnt sure how i would weld it back. maybe if i could cut the frame off another mower then weld it under my frame or something. i wana try to keep the flex in it though. i was thinking about welding some of that c channel (cuz its strong as hell) straight down from the center pivot point then brace the sides of it. where did you get those shocks from on your mower redzz?
redzz02
redzz02
PostSubject: Re: 12hp Craftsman II build ♦lots of pic's♦   12hp Craftsman II build  ♦lots of pic's♦ Icon_minitimeMay 22nd 2012, 10:37 pm
they are 12 inch gokart shocks so basicaly anywhere they sell go kart parts would probably have them
TravisMo
TravisMo
PostSubject: Re: 12hp Craftsman II build ♦lots of pic's♦   12hp Craftsman II build  ♦lots of pic's♦ Icon_minitimeMay 24th 2012, 6:58 pm
ohh i gotcha. so you pretty much made a 3 link suspension in the front. how well does it flex with the trac bar? i was thinking about doing the same thing but with square tubing and maybe small heim joints or something so it will get the most flex and still stay strong.
mowerstompin
mowerstompin
PostSubject: Re: 12hp Craftsman II build ♦lots of pic's♦   12hp Craftsman II build  ♦lots of pic's♦ Icon_minitimeJune 16th 2012, 9:30 pm
Any updates on the mower bud?
https://www.youtube.com/mowerstompin
» 2nd Generation Craftsman Lt1000 Offroad Build - (Pics)
» Yardmachine (lots of pics, sorry)
» crastsman on 33in supper swampers lots of pics and mods
» craftsman 12hp project
» CMHN's Dynamark Build (Warning lots of pictures)
