I did figure out what this thing (transaxle) had in it from the factory I think. Like I mentioned it was thick sticky and had a green tint. Didn't smell like gear oil, but was familiar. Well I chopped down some shrubs that died due to the extreme cold this winter.... I ran into some thick, sticky, and green tinted oil when I cut them down. I'm pretty certain this thing was filled with bar and chain oil.
Pulled out the pressure valve and inserted a barbed nipple on the transaxle. I figured, should I ever go submerged with the trans, the heat of the trans will pop the valve and when it cooled would suck in water when closing. I will run a hose to under the seat. That will give me about 10 more inches height, and put a fuel filter on it.
Slapped on the rear tires to see how they looked. I realized I have the tires clocked on the wheels identically. Not sure if that is good or bad. Just interesting I guess.
really loving the look of the new tires and wheels Mighty, looks so tough. food for thought, Id run the vent line up by the dash, ive gone over seat deep a few times not really expecting to on rusty at haspin
Thanks @creepycrawler! As you can see above on the tire, I have plenty of line.
I was going to lay the fenders back down so I could walk away from the tractor so I can stay under the 50% rule for next year. I noticed some stress cracks around the seat mount holes. In the past I always nasty booger fix or blow holes right and left. I have some thin 6013 rods from my old 110 welder laying around. Put my cable in the lower B channel and the metal thickness to 1/16. I was very happy with the result!
Just about time to throw it back to the way it was with the trans lock so I can still enter it in next year's build-off.
Mighty I think I missed the 2022 build of discussion, when will it start?
I'm hoping to start it Jan 1 next year instead of Feb 1. Waiting on Doug to go through our rough draft of some new rules. If nothing becomes of the rule set, it will more than likely be the same rules.
Sorry if I’m getting the build page off topic, and not to jump the gun, but what sorts of rule alterations are being considered? It’s going to be cool to see a green tractor in the build off , something different.
Top secret at this time.
