 XC Racer Build “Fancy” 27hp Kohler, 820, tons of fab work
5 posters
XC Racer Build “Fancy”     27hp Kohler, 820, tons of fab work  Empty
PostSubject: XC Racer Build “Fancy” 27hp Kohler, 820, tons of fab work    XC Racer Build “Fancy”     27hp Kohler, 820, tons of fab work  Icon_minitimeApril 26th 2021, 2:29 pm
Hey all, been a long time since I posted much but I’m gonna try hard to document my new build. There’s a offroad racing driers in PA that’s hosting there first ever Lawn mower Harescramble, which if your not familiar with harescrambles they are woods races, through the trees, up and down hills, through mud etc. Well this got me all hot and bothered to dig out my old racer project from the weeds and try to resurrect it and race it. I’ve been collecting parts for it for years now but never actually did anything with them, so I figured what better time than now to try to make it happen. It’s a old old Murray frame, I’m reinforcing it and adding a 820, and a 27hp kohler Command.
Picture of it right out of the weeds where it’s been sitting for about 13 years
XC Racer Build “Fancy”     27hp Kohler, 820, tons of fab work  Bd242610
Stripped clear down
XC Racer Build “Fancy”     27hp Kohler, 820, tons of fab work  C1dfdf10
3/4 square tube sub frame mocked up
XC Racer Build “Fancy”     27hp Kohler, 820, tons of fab work  33664c10
PostSubject: Re: XC Racer Build “Fancy” 27hp Kohler, 820, tons of fab work    XC Racer Build “Fancy”     27hp Kohler, 820, tons of fab work  Icon_minitimeApril 26th 2021, 2:35 pm
More work on the subframe, I wanted to use both sets of mounting bolt holes to try to strengthen the 820s case, but the Murray frame was almost exactly on top of the inner bolt holes. I ended up making a set of threaded bungs out of 1/2 steel rod and welding them in so that you can just thread the inner bolts into that.
XC Racer Build “Fancy”     27hp Kohler, 820, tons of fab work  9a342610
You can see the skid plate setup that’s coming together also, it will run basically the entire underside of the tractor, the part that goes under the trans will be 1/16 and the rest thin sheet metal
XC Racer Build “Fancy”     27hp Kohler, 820, tons of fab work  B354c810
Tacked into the frame, I didn’t get one side quite right so I need to cut a few tacks loose and realign
XC Racer Build “Fancy”     27hp Kohler, 820, tons of fab work  7d0e4210
PostSubject: Re: XC Racer Build “Fancy” 27hp Kohler, 820, tons of fab work    XC Racer Build “Fancy”     27hp Kohler, 820, tons of fab work  Icon_minitimeApril 26th 2021, 9:19 pm
I really need a better welder so blowing holes in these thin frames would not be so easy.. LOL  I should have done some kind of bracing like that on KAL.  Looks good.
XC Racer Build “Fancy”     27hp Kohler, 820, tons of fab work  Sig115PROJECTS:
XC Racer Build “Fancy”     27hp Kohler, 820, tons of fab work  Sig214XC Racer Build “Fancy”     27hp Kohler, 820, tons of fab work  Sig314
PostSubject: Re: XC Racer Build “Fancy” 27hp Kohler, 820, tons of fab work    XC Racer Build “Fancy”     27hp Kohler, 820, tons of fab work  Icon_minitimeMay 6th 2021, 9:45 pm
Thanks mighty! I’m really happy with my Miller 211. I’ve been ordering parts and doing some figuring. I was out in the garage the other night and I though man I’m tired of getting up and down so many times working on this thing I need a different solution and this is what I came up with
XC Racer Build “Fancy”     27hp Kohler, 820, tons of fab work  920e6a10
Needs a few tweaks but it works as is, should help speed this build up a fuzz and save my back and knees
PostSubject: Re: XC Racer Build “Fancy” 27hp Kohler, 820, tons of fab work    XC Racer Build “Fancy”     27hp Kohler, 820, tons of fab work  Icon_minitimeMay 8th 2021, 9:39 am
Worked on this a bit last night, got the crane trued up, the front wasn’t quite right the first time. Rotisserie is working good, I shortened the distance between the uprights because it had to much flex the way it was before
XC Racer Build “Fancy”     27hp Kohler, 820, tons of fab work  E0e1df10
Also added a handle to help move it around, and I got a whole cut in the frame above the input shaft so I can start figuring out the location of the support bearing and shaft extension
XC Racer Build “Fancy”     27hp Kohler, 820, tons of fab work  58968c10
BlakeGroce
BlakeGroce
PostSubject: Re: XC Racer Build “Fancy” 27hp Kohler, 820, tons of fab work    XC Racer Build “Fancy”     27hp Kohler, 820, tons of fab work  Icon_minitimeMay 8th 2021, 2:07 pm
Nice work! Its gonna be sweet!, no doubt about that.
PostSubject: Re: XC Racer Build “Fancy” 27hp Kohler, 820, tons of fab work    XC Racer Build “Fancy”     27hp Kohler, 820, tons of fab work  Icon_minitimeDecember 31st 2021, 4:10 pm
XC Racer Build “Fancy”     27hp Kohler, 820, tons of fab work  5e9d4c10
XC Racer Build “Fancy”     27hp Kohler, 820, tons of fab work  2a71c610
XC Racer Build “Fancy”     27hp Kohler, 820, tons of fab work  Cef14510
Been bad at updating, but here’s a photo dump of some work getting done, got the Ninja 300 brakes worked out, also designed up a wheel adapter for my hub system out of aluminum, had my cousin cut it out for me on his home built CNC mini mill, turned out great I think! Really loving the rear tire and wheel setup on here.
Nevadablue likes this post
TechnoChicken
TechnoChicken
PostSubject: Re: XC Racer Build “Fancy” 27hp Kohler, 820, tons of fab work    XC Racer Build “Fancy”     27hp Kohler, 820, tons of fab work  Icon_minitimeDecember 31st 2021, 6:12 pm
Can you shoot a pic of that kolher? 27 HP sounds like a ton of power
PostSubject: Re: XC Racer Build “Fancy” 27hp Kohler, 820, tons of fab work    XC Racer Build “Fancy”     27hp Kohler, 820, tons of fab work  Icon_minitimeDecember 31st 2021, 8:05 pm
yep, its a command, ill try to grab a pic in the next couple days
Nevadablue
Nevadablue
PostSubject: Re: XC Racer Build “Fancy” 27hp Kohler, 820, tons of fab work    XC Racer Build “Fancy”     27hp Kohler, 820, tons of fab work  Icon_minitimeDecember 31st 2021, 9:17 pm
Nice work! I will steal the idea for the ‘deflector’ under the frame to both strengthen and protect the transaxle.
Those brakes are the way to go, IMO. Put on two and there’s no reason for a locker. Like a regular tractor, just brake the slipping wheel.
» Murray Racer Build "Bad Habit"
» USLMRA GP Racer [2017 Build-Off Entry]
» Craftsman Rider 15 HP Kohler Off Road Project Build on Youtube!
» Mid-engined-rat-rod-racer MERRR! [2016 Build-Off Entry]
» [Rules DQ] - bow tie mud guy's FXT oval track racer MISTRESS! [2019 Build-Off Entry] *
