I have a tractor that I'm giving some off road treatment for my dad. He's 78 and needs something that he can ride around our property, and from his workshop to home and whatnot.
I came across a husqvarna YTH2242A tractor for a good price since the guy didn't have a deck for it and had used it to haul his wood wagon. Hydrostatic trans I'm going to replace with an MST 206-545c that I bought last weekend.
So, my questions are about putting ATV tires on it, and doing a 4 on 4 front hub conversion.
The rear tires on there right now, are 20 x 10 x 8. I think I'd like them a little taller, like 22 I think I could do without having to hack the fenders.
For the fronts, what do you guys do? I was going to buy some 8" wheels to replace the 6" on there, but really I'd like the tires in the front to be as big as the rears, but narrower. Like a quad. I figure the bigger the tires, and running them at a lower pressure the ride will be more comfy for the old man. I guess with the hub conversion I could run just about any size wheel...... Of course the width and offset will be important so that I can still have some decent steering angle without rubbing.
Thoughts, advice?
Much appreciated
Zzeke
Age : 24 Join date : 2016-04-12 Points : 5976 Posts : 2645 Location : Indiana
You’ll probably want a custom front axle. If you can source a complete golf cart axle to shorten, that will give you some hubs, spindles, good bearings, and the knuckles to work with. Bonus, stock golf cart wheels are 8”
Age : 49 Join date : 2016-09-06 Points : 15654 Posts : 10975 Location : Oklahoma
I run 4 on 4 gokart hubs from bmikart and replace with the bearing size needed. I think they come with 5/8 bore bearing, but you can replace with a 3/4 one if your spindles are that size. I had to trim about 1/4 to 1/2 inch off them to fit with stock retainer. I think gopowersports have them too.
I like the idea of just using different bearings, and I hadn't thought of trimming the housing to get it to fit as stock - clever.
I can see though, if it was going to be ridden hard may want to have a look at beefier axle. Was thinking of doing that at some point for the old man, if I could figure out some sort of suspension.
The smart and thrifty thing to do is use golf cart wheels. I can buy them powdered black for less money than I could get the ones I have powdered black.
I think next step is to get the hubs and do some test fitting.
Thanks again gents.
Zz
Join date : 2021-01-15 Points : 2877 Posts : 1340 Location : Upstate New York
Welcome to the forum! If you aren’t opposed to keeping the stock rims you can put in ball bearings if the spindles are in good condition or put on new spindles for 30 or so for a set. Bearings I think are about 20 for a set of 4. You can put ATV tires on a GT rim. Got any pictures?
Thanks Rusty! That's is a good tip.
Kinda leaning toward replacing all the wheels with golf cart wheels, for simplicity and cost. I do want a larger tire in front for lower pressure passive suspension if you get my drift.
I think I found some hubs I like, need to see if my spindles are long enough to try them. I'll throw some gussets on them for a little added reinforcement.
