 Thinking about wheels and tires.
BairleaFarm
6 posters
BairleaFarm
BairleaFarm
Thinking about wheels and tires. Empty
PostSubject: Thinking about wheels and tires.   Thinking about wheels and tires. Icon_minitimeNovember 20th 2023, 9:18 am
Thinking out loud here. I build a lot of crap and move wheels and tires around all the time. mowers, trailers, off-road builds etc. I got these golf cart wheels and tires for free. 4x4 lug pattern which is also the same as a lot of the atv wheel and tire combos that are available in my area. These are typically cheaper and plentiful. The hubs for both live axle and roller bearing type are also cheap. I've got half a mind to switch everything over to this lug patters. 14" used wheel and tire combos are also readily available for cheap.
Thoughts, pros, or cons?
Thinking about wheels and tires. 40242310
Thinking about wheels and tires. Hub110
Thinking about wheels and tires. Wheel10
PostSubject: Re: Thinking about wheels and tires.   Thinking about wheels and tires. Icon_minitimeNovember 20th 2023, 9:36 am
I think you laid out the pros and cons!  I always love easy quick interchangeable.  Finding wheels are cheap in your area.  I'd probably go for it.  Nothing says you have to stay with garden tractor wheels.  You have pictured live axle 1 inch to 3/4 step down.  You may want to look at that part again. If you have a 1 inch rear, you would want that straight through.
Thinking about wheels and tires. Sig115PROJECTS:
Thinking about wheels and tires. Sig214Thinking about wheels and tires. Sig314
Rustbucket Garage
Rustbucket Garage
PostSubject: Re: Thinking about wheels and tires.   Thinking about wheels and tires. Icon_minitimeNovember 20th 2023, 9:52 am
What size are your front spindles? Those trailer hubs can take 1” R16 bearings if you bore them out .20 thou.
BairleaFarm
BairleaFarm
PostSubject: Re: Thinking about wheels and tires.   Thinking about wheels and tires. Icon_minitimeNovember 20th 2023, 10:20 am
The current build has 1" spindles.
Rustbucket Garage
Rustbucket Garage
PostSubject: Re: Thinking about wheels and tires.   Thinking about wheels and tires. Icon_minitimeNovember 20th 2023, 12:09 pm
There ya go! If you got a lathe it’s an easy conversion, if not somebody would probably do it for 40 bucks.
1” spindles are the best, while the 3/4 guys are over there having to reinforce em we can just go rock bouncing without a care in the world! Lol
BairleaFarm
BairleaFarm
PostSubject: Re: Thinking about wheels and tires.   Thinking about wheels and tires. Icon_minitimeNovember 20th 2023, 12:41 pm
So would any or all of these need to be machined? You are referring to the bearing correct?
PostSubject: Re: Thinking about wheels and tires.   Thinking about wheels and tires. Icon_minitimeNovember 20th 2023, 8:17 pm
There are a few guys that converted to trailer spindles, the best thing about them is having the adjustment of a tapered roller bearing, as well as nice seals to keep grease in and grit out. I will be going to trailer hubs on mutt before too long.
There are trailer hubs that go onto a 1" spindle, they need a threaded adjustment though which you would have to add to your spindles, granted they were long enough in the first place.
BairleaFarm
BairleaFarm
PostSubject: Re: Thinking about wheels and tires.   Thinking about wheels and tires. Icon_minitimeNovember 20th 2023, 8:28 pm
EDIT
Rustbucket Garage
Rustbucket Garage
PostSubject: Re: Thinking about wheels and tires.   Thinking about wheels and tires. Icon_minitimeNovember 20th 2023, 9:02 pm
The first one you posted is keyed and isn’t suitable for front spindles.
The trailer hubs would need .10 thou removed from the wall on both ends where the races ride. The tapered bearings are 1.98 inches in diameter while ball bearings are 2 inches, .20 thou is too much interference for a press fit IMO.
You can’t really use tapered bearings on these shafts because you’ll need to thread the end for a spindle nut, and the seal surface is 1.25 inches in diameter.
PostSubject: Re: Thinking about wheels and tires.   Thinking about wheels and tires. Icon_minitimeNovember 20th 2023, 9:35 pm
The trailer hub upgrade was a challenging metal fab project but the payoff is so worth it. It's so nice being able to remove a front wheel quickly without a greasy mess. The mock up part took a while to get the chamber and track width right.
MightyRaze and Hammernco like this post
JB_4x4
PostSubject: Re: Thinking about wheels and tires.   Thinking about wheels and tires. Icon_minitimeDecember 17th 2023, 5:34 am
FWIW: I am working on converting all my small trailers and mowers to 4 on 4, except maybe one RER Snapper because of the 3 lug wheels. Messing with cotter pins and heating caps to get at them, just to change a wheel is a hassle. Today after fighting getting 13" tires on 6" rims, I have decided to move fronts and backs to larger rims and 4 on 4 patterns. The other advantage is I can add front disc brakes with the bigger 8" wheels.
» Need input on 4 on 4 hub conversion, wheels, and larger front tires
» What have you done to your tractor today?
» Thinking about tracks
» I'm thinking of a new tractor - are you too? Post here!
» What do you think is the most popular Tractor?
