 how do you lift a lawnmwer?
Dustin138
Dustin138
how do you lift a lawnmwer? Empty
PostSubject: how do you lift a lawnmwer?   how do you lift a lawnmwer? Icon_minitimeSeptember 19th 2011, 5:43 pm
I want to lift my lawnmower to fit 22 inch atv tires instead of the 18inch tires. How do i lift the lawn mower to fit theese ? confused confused Question Question
craftsman30mph
craftsman30mph
PostSubject: Re: how do you lift a lawnmwer?   how do you lift a lawnmwer? Icon_minitimeSeptember 19th 2011, 5:46 pm
what kind of tranny do you have? if it is a 5 speed peerless like mine you can check out my pics and see how I did my lift
Dustin138
Dustin138
PostSubject: Re: how do you lift a lawnmwer?   how do you lift a lawnmwer? Icon_minitimeSeptember 19th 2011, 6:03 pm
i have a White(mtd). is has a variable pulley from what i heard. I dont know the company that made the tranny.
arild365
arild365
PostSubject: Re: how do you lift a lawnmwer?   how do you lift a lawnmwer? Icon_minitimeSeptember 19th 2011, 6:59 pm
my craftsman has 22 inch tires and my buddy has 24s and they fit under the fenders pretty well! had to trim a tiny bit but hardly none.
Dustin138
Dustin138
PostSubject: Re: how do you lift a lawnmwer?   how do you lift a lawnmwer? Icon_minitimeSeptember 19th 2011, 7:18 pm
Here are some photos of the trans-axel.
how do you lift a lawnmwer? P9200003
how do you lift a lawnmwer? P9200001
PostSubject: Re: how do you lift a lawnmwer?   how do you lift a lawnmwer? Icon_minitimeSeptember 20th 2011, 5:12 am
Itd be easier with a manual trans - its not just moving the transaxle, youd have to relocate the variable pulley and other pieces as well.
The bracket that mounts to the front of the transaxle would need to lowered, its possible to flip the variable pulley setup to bring the belt down, the shift levers would need to be extended - youd need alot of steel to make all the brackets.
Or you can just remount the fenders up higher- thats the easiest fix i can think of.
Dustin138
Dustin138
PostSubject: Re: how do you lift a lawnmwer?   how do you lift a lawnmwer? Icon_minitimeSeptember 20th 2011, 7:09 am
i will try raising the fenders
» A Basic but Strong Lift, for Your Tractor (based on a homebuilt subaru lift).
» Small lift
» What is best way to lift your lawnmower?
» How do you lift mower????????
» How do I lift a Craftsman?
