| I GOT A WORKSPACE (but it needs work like everything else) | |
yeethaw Member
Age : 19 Join date : 2019-04-23 Points : 2271 Posts : 182 Location : beecher il
| Subject: I GOT A WORKSPACE (but it needs work like everything else) December 9th 2019, 6:01 pm | |
| So we have a storage container that Hasn’t been used in a while so I got permission from my dad to use it as a space to work on my tractor and other projects but it has two problems 1 inside it’s VERY humid to the point where the engines on the sealing equipment are all seized so I need a way to get the humidity down in there 2 since it’s been used to store grease/oil/90 weight/gas/diesel and every other liquid imaginable there’s a coating of mostly grease on the floor that’s been there so long it’s mixed with rust so I need advice on a way of cleaning that off | |
Age : 24 Join date : 2016-04-12 Points : 5987 Posts : 2645 Location : Indiana
TheBeal Veteran Member
Age : 30 Join date : 2013-06-06 Points : 5723 Posts : 1402 Location : Central PA
| Subject: Re: I GOT A WORKSPACE (but it needs work like everything else) December 9th 2019, 7:58 pm | |
| I mean... do you REALLY need to clean the floor off? I think that would take alot of solvent to clean well.
Throw down some sawdust in any wet areas, and just use it. It will clean up after a while.
Get some vents or windows in there and a fan. That should help. Assuming you have power in there, a dehumidifier would also be a good idea.
If you could find a solar panel, that could be rigged up with a fan and dehumidifier. | |
yeethaw Member
mrshaft696 Established Member
Join date : 2016-07-10 Points : 4065 Posts : 870 Location : Phillydelphia
| Subject: Re: I GOT A WORKSPACE (but it needs work like everything else) December 10th 2019, 9:58 am | |
| yeah I would certainly cut a window or a sunroof, you will probably choke on fumes if that is what has been in there....
Is the floor metal then I take it? I would scrub it clean and paint it with garage floor paint, or just put rubber mats over top of it where you want to work. | |
yeethaw Member
| Subject: Re: I GOT A WORKSPACE (but it needs work like everything else) December 10th 2019, 10:52 am | |
| the floors metal and i cant really cut a hole in it since its not mine but the fumes arent that bad and will mostly go away if i air it out a while but what im prolly gonna go for the floor is scrape all the stuff into a pile with a shovel and throw it out and then try to clean whats left up with some old gas | |
yeethaw Member
Age : 34 Join date : 2013-11-02 Points : 7175 Posts : 2910 Location : New Jersey USA
| Subject: Re: I GOT A WORKSPACE (but it needs work like everything else) December 11th 2019, 1:03 am | |
| I can feel myself getting a headache thinking of smelling the bad gas fumes. I suppose a bit at a time might clean it up a bit. But if there's any thick coating, then yeah I guess scrape that out with a shovel first. Pics tho man pics!
And if you have any power nearby then you'd be set. A dehumidifier would definitely handle a space that small. If you had a rusty spot somewhere near the floor and could just poke a hole big enough to get a garden hose though. Then you'd really be set. You'd never have to empty the dehumidifier. | |
yeethaw Member
| Subject: Re: I GOT A WORKSPACE (but it needs work like everything else) December 11th 2019, 7:59 am | |
| Welp I got it organized in a way that I can get the tractor in to work on it but the current problem is that all the floor crud has become frozen so It’s a paint to get it off and I’m probably just gonna wait till tomorrow since it’ll be above freezing for once | |
yeethaw Member
yeethaw Member
