| | how does this work? | |
+3Stretch44875 Doc Sprocket 1997 Murray 7 posters | Author | Message |
1997 Murray Veteran Member
Age : 25 Join date : 2013-11-13 Points : 5372 Posts : 1311 Location : NW USA
![how does this work? Empty](https://2img.net/i/empty.gif) | Subject: how does this work? January 15th 2014, 3:22 pm | |
| how does this locker work? this is a bolens selectable locker: ![how does this work? 1050_parts1](https://2img.net/h/www.samsbolens.com/images/1050_parts1.png) | |
| ![Go down](https://2img.net/i/empty.gif) | | Doc Sprocket Site VIP
![how does this work? Empty](https://2img.net/i/empty.gif) | Subject: Re: how does this work? January 15th 2014, 3:51 pm | |
| That's not a locker, that's a whole dang transaxle. That said, MANY compact and fullsize tractors have a differential lock, often actuated by a pedal. There's a few different systems out there, but they all basically boil down to a mechanical coupling that overrides the differential action of the spider gears. | |
| ![Go down](https://2img.net/i/empty.gif) | | Stretch44875 Administrator
![Stretch44875](https://2img.net/u/2812/37/66/46/avatars/314-28.jpg)
Age : 49 Join date : 2012-04-05 Points : 5627 Posts : 959 Location : Mansfield, Ohio
![how does this work? Empty](https://2img.net/i/empty.gif) | Subject: Re: how does this work? January 16th 2014, 6:29 am | |
| Parts 69 and 68 slid together, and lock axle to diff carrier. | |
| ![Go down](https://2img.net/i/empty.gif) | | redlinemotorsportts Moderator
![how does this work? Empty](https://2img.net/i/empty.gif) | Subject: Re: how does this work? January 16th 2014, 6:46 am | |
| I believe parts #11 and #8 create the locking diff. Would be a good concept for a modern transaxle!
Last edited by redlinemotorsportts on January 16th 2014, 10:21 am; edited 2 times in total | |
| ![Go down](https://2img.net/i/empty.gif) | | TheRainbowBoxer Moderator
![TheRainbowBoxer](https://2img.net/u/2812/37/66/46/avatars/326-23.jpg)
Age : 49 Join date : 2012-04-23 Points : 5627 Posts : 1091 Location : Galion, OH
![how does this work? Empty](https://2img.net/i/empty.gif) | Subject: Re: how does this work? January 16th 2014, 7:42 am | |
| I'm not exactly a pro at reading exploded views, but it looks like what Red said is what actuates what Stretch said. | |
| ![Go down](https://2img.net/i/empty.gif) | | 1997 Murray Veteran Member
![how does this work? Empty](https://2img.net/i/empty.gif) | Subject: how does this work? January 16th 2014, 10:39 am | |
| thanks guys! I was wondering how it locked, I couldn't figure it out from the picture ![how does this work? Icon_rolleyes](https://2img.net/i/fa/i/smiles/icon_rolleyes.gif) | |
![how does this work? Empty](https://2img.net/i/empty.gif) | Subject: Re: how does this work? January 16th 2014, 11:04 am | |
| When all else fails, read the manual. http://sonnys_bolens.tripod.com/manuals/images/tubeframe/OwnerManuals/192-02-OM.pdfThe pin that Red refers to is actually the freewheeling pin. It is pulled to disengage the wheels from the transmission, and allow the tractor to be pushed. 8 and 6 are locked together with the 11 pin. 6 is the wheel hub. Notice how it is a solid axle(53), through the diff(67)? Huh?(that's what I though anyways!) The left side hub(54) spins on that solid axle(53), and is driven by the left side spider gears. You lock the rear by locking the left hub,54 to the axle,53 that it can spin on. Part 45 is able to be turned, and is actually an adjustable limited slip. You can tighten it, and it locks the hub and axle with friction washers. It's not actually a locker, but can be adjusted tight enough to give almost locker action. The parts(67, 69) I was looking at lock the solid axle to the right side spider gears. This is what doing drafting classes, and doing journeyman machine repair work gets you.... | |
![how does this work? Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | 1997 Murray Veteran Member
![how does this work? Empty](https://2img.net/i/empty.gif) | Subject: how does this work? January 16th 2014, 11:29 am | |
| that is interesting....... I wish all of the trannys where made unlimited slip like that | |
| ![Go down](https://2img.net/i/empty.gif) | | Lawren Wimberly Established Member
![Lawren Wimberly](https://2img.net/u/2812/37/66/46/avatars/1273-1.jpg)
Age : 57 Join date : 2013-12-21 Points : 4731 Posts : 744 Location : Salem Illinois
![how does this work? Empty](https://2img.net/i/empty.gif) | Subject: Re: how does this work? January 16th 2014, 11:48 am | |
| The correct answer to your question
"How does this work?" is....
not at all exploded like that! | |
| ![Go down](https://2img.net/i/empty.gif) | | T-Dub13 Established Member
![T-Dub13](https://2img.net/u/2812/37/66/46/avatars/1235-78.jpg)
Age : 54 Join date : 2013-12-06 Points : 4498 Posts : 540 Location : Central MA
![how does this work? Empty](https://2img.net/i/empty.gif) | Subject: Re: how does this work? January 16th 2014, 11:54 am | |
| Yeah, that's a great little feature! Nice top loader transaxle too. They don't make 'em like they used to! | |
![how does this work? Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | | how does this work? | |
| Who is online? | In total there are 132 users online :: 1 Registered, 0 Hidden and 131 Guests ranch king pro 08Most users ever online was 412 on January 7th 2023, 7:59 am |
