 Will it work?
Torotorquehorse
Will it work? Empty
PostSubject: Will it work?   Will it work? Icon_minitimeAugust 10th 2014, 12:38 am
I have a toro wheel horse that is soon to be my mussing mower, but I'm not sure about the transaxle. If I do a 1:1 pulley ratio and lock the transaxle would it hold up with 23x9.50-12 rear tires the transaxle is a peerless 820-024 it is a 6-speed. I have heard that these transaxles are tough but, I don't know if it would hold up with my tire size. (I plan on getting good tires for off roading)
Will it work? Empty
PostSubject: Re: Will it work?   Will it work? Icon_minitimeAugust 10th 2014, 9:07 am
it should hold up, the tire size you are running is what is used stock with the 820. my mst holds up to a 2:1 ratio and atv tires, so your 820 should be just fine.
CornShuck4CE
CornShuck4CE
Will it work? Empty
PostSubject: Re: Will it work?   Will it work? Icon_minitimeAugust 10th 2014, 1:37 pm
I run 26x12-12 on my murray 820-029 locked. Thay have alot of grip and i do whatever i wont with no mercy on the trans and seems to love the abuse.
Will it work? Empty
PostSubject: Re: Will it work?   Will it work? Icon_minitimeAugust 10th 2014, 5:23 pm
most tracors that got a 820's have 23-12x12 tires I believe. So yes it will work.
Torotorquehorse
Will it work? Empty
PostSubject: Thanks   Will it work? Icon_minitimeAugust 11th 2014, 2:42 pm
Thanks for the info everyone and I will post a thread when I start the build
Will it work? Empty
PostSubject: Re: Will it work?   Will it work? Icon_minitimeAugust 11th 2014, 4:01 pm
Not a problem. Smile
Will it work? Empty
Will it work?
» clutch doesnt work and pulleys wont work
» Will this work?
» how does this work?
» How would this work?
» How well would this work?
