 Briggs Pressure Lube Opposed Twin Cleanup
Biggkidd
10 posters
Go to page : Previous  1, 2
Briggs Pressure Lube Opposed Twin Cleanup - Page 2 Empty
PostSubject: Re: Briggs Pressure Lube Opposed Twin Cleanup   Briggs Pressure Lube Opposed Twin Cleanup - Page 2 Icon_minitimeFebruary 17th 2020, 1:18 am
Well I've finally been making some headway on the reassembly of this engine lately:
Briggs Pressure Lube Opposed Twin Cleanup - Page 2 20200237
Got the pistons/rods and the flywheel installed and all torqued up.
Briggs Pressure Lube Opposed Twin Cleanup - Page 2 20200238
The base was just stuck in place in that picture, but tonight I actually got it bolted on and sealed up. Got a new lower crank seal for it too:
Briggs Pressure Lube Opposed Twin Cleanup - Page 2 20200239
New crank seal put in and and oil pump reassembled:
Briggs Pressure Lube Opposed Twin Cleanup - Page 2 20200240
Not too bad! Man it'll be nice to finally have it running again, haha. Getting the head gaskets somtime this week, and after that I should need any more parts.
PostSubject: Re: Briggs Pressure Lube Opposed Twin Cleanup   Briggs Pressure Lube Opposed Twin Cleanup - Page 2 Icon_minitimeFebruary 18th 2020, 8:00 am
nice, looking back I like the squeeze clamp compressor...
PostSubject: Re: Briggs Pressure Lube Opposed Twin Cleanup   Briggs Pressure Lube Opposed Twin Cleanup - Page 2 Icon_minitimeFebruary 18th 2020, 3:45 pm
Looking good! Cleaner looking than most of my corroded engines lol.
PostSubject: Re: Briggs Pressure Lube Opposed Twin Cleanup   Briggs Pressure Lube Opposed Twin Cleanup - Page 2 Icon_minitimeMarch 22nd 2020, 7:52 pm
Thanks fellas!
Little more progress on the worlds slowest engine reassembly today. I got my head gaskets a little bit ago, so I was able to get the heads on with thr new gaskets and torque them up. I also got the back cover, starter, and flywheel fan installed:
Briggs Pressure Lube Opposed Twin Cleanup - Page 2 20200331
Briggs Pressure Lube Opposed Twin Cleanup - Page 2 20200332
Starting to look more like an engine! Shouldn't need to wait for any parts for it now, so I should be able to just continue putting it back together.
PostSubject: Re: Briggs Pressure Lube Opposed Twin Cleanup   Briggs Pressure Lube Opposed Twin Cleanup - Page 2 Icon_minitimeMarch 22nd 2020, 9:46 pm
Excellent. Can't wait to hear the ol engine fire up! Briggs Pressure Lube Opposed Twin Cleanup - Page 2 2731072446 Briggs Pressure Lube Opposed Twin Cleanup - Page 2 2731072446 Briggs Pressure Lube Opposed Twin Cleanup - Page 2 2731072446
Briggs Pressure Lube Opposed Twin Cleanup - Page 2 Sig115PROJECTS:
Briggs Pressure Lube Opposed Twin Cleanup - Page 2 Sig214Briggs Pressure Lube Opposed Twin Cleanup - Page 2 Sig314
PostSubject: Re: Briggs Pressure Lube Opposed Twin Cleanup   Briggs Pressure Lube Opposed Twin Cleanup - Page 2 Icon_minitimeMarch 23rd 2020, 3:04 pm
Looking good Allis. Interesting oil pump cover, I've never seen one like that.
PostSubject: Re: Briggs Pressure Lube Opposed Twin Cleanup   Briggs Pressure Lube Opposed Twin Cleanup - Page 2 Icon_minitimeMarch 24th 2020, 8:18 pm
Thanks guys. It's going slow but I'm looking forward to hearing it running again.
» opposed twin pressure lube part and info
» wanted briggs opposed pressure lube blocks, sumps, and cams and cranks
» Entire Opposed Pressure lube Internals Swap & Info
» How to: Hook up a Diesel tachometer to a Briggs Opposed Twin or any Briggs with AC out.
» Back Pressure!! Is it good for our briggs single or twin or is it bad?
