 opposed twin pressure lube part and info
5 posters
Conntech15
opposed twin pressure lube part and info Empty
PostSubject: opposed twin pressure lube part and info   opposed twin pressure lube part and info Icon_minitimeJuly 21st 2022, 1:59 pm
hello!
Does anyone know the part numbers for the crank, cam, block, and sump for the pressure lubed briggs, opposed twin.
are the pistons/rings different on the pressure lubes?
the heads are gonna be the same im pretty sure, or will fit atleast.
gonna get arc rods
im looking to build up a pressure lubed oppy, and only that. will not change my plans.
Conntech15
PostSubject: Re: opposed twin pressure lube part and info   opposed twin pressure lube part and info Icon_minitimeJuly 21st 2022, 2:09 pm
so, i know some people are gonna be wondering what exactlly im gonna be cooking up.
so my plan is to build a pressure lubed oppy, bored for the oversized pistons (30 thou) and oversized rings (30 thou). for a total of 60 thou over the 3.5625 bore of the big bore block. then polish all of the surfaces of the block (excluding main crank bearing locations, cam-holder, and cylinders). then im gonna port and polish both intake and exhaust ports and attempt to grind a "golf ball" pattern into the intake to allow fuel/air to mix better (otherwise the polishing would be harmful to the mixing of fuel and air as the rough surface assists in doing so.) rods will be replaced with arc racing ball bearing pressure lube rods. dual carburetors with a common pulse pump (both use the same pump, combined vacuum line.) the intake manifolds will be custom made with a "rifling" pattern to make a vortex, mixing the fuel better. the pcv will have a catch can. and a common filter for both carbs, with a velocity stack on the intake cover. arc flywheel (not sure about adjusting the ignition timing.) and using the crank with the farthest offset (not sure if thats from a 42, 46 or 40ci opposed) to have the maximum stroke. im gonna shave the "eyebrows" for more flow, grind the head around the same area for more room, and then plane the entire head down for more compression.
Conntech15
PostSubject: Re: opposed twin pressure lube part and info   opposed twin pressure lube part and info Icon_minitimeJuly 21st 2022, 2:12 pm
oh and im looking to paint the exterior with engine enamel.
Conntech15
PostSubject: Re: opposed twin pressure lube part and info   opposed twin pressure lube part and info Icon_minitimeJuly 21st 2022, 2:14 pm
a guy calling himself "rooster, did some mods to a crank, allowing the oil to get at the journal better, but i think it would need rebalanced, and i dont have the means to do that.
Conntech15
PostSubject: Re: opposed twin pressure lube part and info   opposed twin pressure lube part and info Icon_minitimeJuly 21st 2022, 2:17 pm
also, not much experience, period. all based on research im open to corrections, discussions and idea's.
PostSubject: Re: opposed twin pressure lube part and info   opposed twin pressure lube part and info Icon_minitimeJuly 21st 2022, 2:34 pm
Phew! Whirlwind post!
Do you have a pressure lube Oppy? Those are unicorns where I live. @AllisKidD21 has one. If you have one and have the model and code badge on it still. You can head over to
https://www.briggsandstratton.com/na/en_us/home.html
At the top hover over (Owner Support) then select (Find Manual & Parts List) select (B&S Engine ) then Engine on (Riding Mower) "Next Step" then type in your model-type in the box to find parts listings.
opposed twin pressure lube part and info Sig115PROJECTS:
opposed twin pressure lube part and info Sig214opposed twin pressure lube part and info Sig314
PostSubject: Re: opposed twin pressure lube part and info   opposed twin pressure lube part and info Icon_minitimeJuly 21st 2022, 2:41 pm
42D777-1281-01 appears to be a pressure lube if you do not have #'s available.
https://www.thepowerportal.com/ipls/ipl.htm?md=42D777128101~_IPLURL_LO.pdf
Rustbucket Garage
Rustbucket Garage
PostSubject: Re: opposed twin pressure lube part and info   opposed twin pressure lube part and info Icon_minitimeJuly 21st 2022, 3:05 pm
Knowing Briggs, they’re probably the same. If in doubt, stick em side by side and compare.
Conntech15
PostSubject: Re: opposed twin pressure lube part and info   opposed twin pressure lube part and info Icon_minitimeJuly 21st 2022, 3:24 pm
see that's the problem, i havnt been able to find a pressure lube, only splash (two of those). figuring maybe i could buy the block, cam, sump, crank from ebay or someone if i knew said part numbers
Conntech15
PostSubject: Re: opposed twin pressure lube part and info   opposed twin pressure lube part and info Icon_minitimeJuly 21st 2022, 3:28 pm
shouldnt the cam shafts be hollow for pressure lubed engines? , the part number brings up a solid cam.
Conntech15
PostSubject: Re: opposed twin pressure lube part and info   opposed twin pressure lube part and info Icon_minitimeJuly 21st 2022, 3:36 pm
opposed twin pressure lube part and info Captur10
i guess i found out about the remored "radiator" for the oil lol
PostSubject: Re: opposed twin pressure lube part and info   opposed twin pressure lube part and info Icon_minitimeJuly 21st 2022, 3:38 pm
Parts are different between splash and pressure. Check out the following thread on a pressure breakdown.
https://www.atltf.com/t4761-entire-opposed-pressure-lube-internals-swap-info
Conntech15
PostSubject: Re: opposed twin pressure lube part and info   opposed twin pressure lube part and info Icon_minitimeJuly 21st 2022, 3:58 pm
opposed twin pressure lube part and info 3a10
opposed twin pressure lube part and info 3b10
opposed twin pressure lube part and info Splash10
these are two of three types, splash and (actually full pressure lube?)
Budget_gokart
Budget_gokart
PostSubject: Re: opposed twin pressure lube part and info   opposed twin pressure lube part and info Icon_minitimeJuly 24th 2022, 1:11 pm
Actually i think i have two pressure lube oppys
PostSubject: Re: opposed twin pressure lube part and info   opposed twin pressure lube part and info Icon_minitimeJuly 24th 2022, 7:44 pm
They both have oil filters?
» 18.5hp opposed twin?
» Briggs Pressure Lube Opposed Twin Cleanup
» wanted briggs opposed pressure lube blocks, sumps, and cams and cranks
» Back Pressure!! Is it good for our briggs single or twin or is it bad?
» 18.5 hp opposed twin
