| | Yard machine front travel | |
Austin_Gore Member
![Austin_Gore](https://2img.net/u/2812/37/66/46/avatars/3473-29.jpg)
Age : 20 Join date : 2019-09-05 Points : 1944 Posts : 93 Location : Fayetteville, Tn
![Yard machine front travel Empty](https://2img.net/i/empty.gif) | Subject: Yard machine front travel September 10th 2019, 3:03 pm | |
| how do i get the most travel out of a lawn mowers front axle pivot bar | |
![Yard machine front travel Empty](https://2img.net/i/empty.gif) | Subject: Re: Yard machine front travel September 10th 2019, 3:18 pm | |
| Bumping question topic to the TECH section.
- Basic geometry, you will need to lower your pivot point to have more swing. (your other thread you mentioned looking for speed. Speed + More axle pivot room = death wobble; Typically those that want more speed lock up their front suspension.
- or mod your axle to clear more room for the frame stop
- scrap the whole thing and do custom suspension
| ![Go down](https://2img.net/i/empty.gif) | | AllisKidD21 Moderator
![Yard machine front travel Empty](https://2img.net/i/empty.gif) | Subject: Re: Yard machine front travel September 10th 2019, 3:21 pm | |
| Well answering that question is rather difficult without seeing a picture of the front end setup... but I assume there are some spots on the frame that can be cut away to allow for more articulation.
Also a post like this belongs somewhere In the Technical Section, just so you know.
EDIT- Ah, I see Mighty already beat me to it, haha. ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| ![Go down](https://2img.net/i/empty.gif) | | Austin_Gore Member
![Yard machine front travel Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | mr.modified Veteran Member
![Yard machine front travel Empty](https://2img.net/i/empty.gif) | Subject: Re: Yard machine front travel September 10th 2019, 5:01 pm | |
| Looks like the pins (#34) kinda hold things in place and possibly limit articulation. Also that cover thing (#36) might hit the axle I'm not sure. Maybe that's what actually limits it and the pins just hold the plate on. If you wanted more travel, you'd have to see what hits. Might be able to cut the top edges of #36 back a bit, but I would think you could only go so far before those pins contact the end of the slots in the front axle.
Other than that, if you can weld, you can figure out some sort of different front end setup or even do front suspension. Just gotta keep in mind the steering needs some clearance too. | |
| ![Go down](https://2img.net/i/empty.gif) | | prancstaman Veteran Member
![Yard machine front travel Empty](https://2img.net/i/empty.gif) | Subject: Re: Yard machine front travel September 10th 2019, 5:58 pm | |
| MTD designed. #34 are the bolt stops for the front axle pivot and hold the front axle assembly together. You could get a little more pivot by making the curved slots in the axle longer but you are weakening a weak axle to begin with. I have one of those on mine. | |
| ![Go down](https://2img.net/i/empty.gif) | | Murraymountain Veteran Member
![Murraymountain](https://2img.net/u/2812/37/66/46/avatars/3368-77.jpg)
Join date : 2019-02-04 Points : 4357 Posts : 2177 Location : North Carolina
![Yard machine front travel Empty](https://2img.net/i/empty.gif) | Subject: Re: Yard machine front travel September 10th 2019, 6:09 pm | |
| - prancstaman wrote:
- MTD designed. #34 are the bolt stops for the front axle pivot and hold the front axle assembly together. You could get a little more pivot by making the curved slots in the axle longer but you are weakening a weak axle to begin with. I have one of those on mine.
Yep. Or if you wanted to be really cheap you could just simply remove those bolts, but then you'd kill any strength factor that's there. | |
![Yard machine front travel Empty](https://2img.net/i/empty.gif) | Subject: Re: Yard machine front travel September 10th 2019, 6:22 pm | |
| I wouldn't mind having that cast iron front axle option. Wonder what models those are in? | |
![Yard machine front travel Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | | Yard machine front travel | |
| Who is online? | In total there are 48 users online :: 0 Registered, 0 Hidden and 48 Guests
