 Yard machine speed help
Austin_Gore
7 posters
Austin_Gore
Austin_Gore
Yard machine speed help Empty
PostSubject: Yard machine speed help   Yard machine speed help Icon_minitimeSeptember 6th 2019, 11:24 am
I have a yard machine mower that hase a vari-drive and idk how to do a pulley swap with a vari-drive
PostSubject: Re: Yard machine speed help   Yard machine speed help Icon_minitimeSeptember 6th 2019, 11:39 am
I think there are some threads in the past that talked about the vari-drive setup. If you use the search bar and look for vari-drive you might find something. Some people don't care much for them and they can be kinda touchy as far as throwing belts ect. Not sure if anyone had too much luck with them or not. I had one on a stock grass cutter and it would chew belts up all the time. I might not have had the exact size belt on it though.
Also, welcome to the forum!
Austin_Gore
Austin_Gore
PostSubject: Re: Yard machine speed help   Yard machine speed help Icon_minitimeSeptember 6th 2019, 11:42 am
Could I take off the vari-drive system and I've looked throught the old threads already.
PostSubject: Re: Yard machine speed help   Yard machine speed help Icon_minitimeSeptember 6th 2019, 1:05 pm
I think you could but isn't the transmission on those just a forward, neutral, reverse trans? If you had a 5 speed or some other transaxle then you would have different gears at least. I think the frames are not much different than most other tractors so you could swap it around sure. Might need to change the clutch ect to make it work with a different belt setup.
Austin_Gore
Austin_Gore
PostSubject: Re: Yard machine speed help   Yard machine speed help Icon_minitimeSeptember 6th 2019, 2:17 pm
You think so??
Question
PostSubject: Re: Yard machine speed help   Yard machine speed help Icon_minitimeSeptember 6th 2019, 2:28 pm
Yeah if you feel ambitious you can rig up a clutch and swap a different transaxle into it, it's been done before.
Last edited by AllisKidD21 on September 10th 2019, 2:50 pm; edited 1 time in total
PostSubject: Re: Yard machine speed help   Yard machine speed help Icon_minitimeSeptember 6th 2019, 3:00 pm
Welcome to the Forum! Fayetteville? Your the closest member to me I know of....
An MTD isn't always the best way to go, but if you want to take a swing at it then go ahead, but definitely get rid of the Varidrive system, they are a PAIN to work with. As for the tranny, just have a spare one around if you're gonna use the FNR. But, if you have a good welder and plenty of drive than you can be like AK above me there and build something awesome!
PostSubject: Re: Yard machine speed help   Yard machine speed help Icon_minitimeSeptember 6th 2019, 3:42 pm
Ah I see you got a topic. :-)
Yard machine speed help Sig115PROJECTS:
Yard machine speed help Sig214Yard machine speed help Sig314
PostSubject: Re: Yard machine speed help   Yard machine speed help Icon_minitimeSeptember 6th 2019, 4:04 pm
The vari drive I had was in a craftsman. Not sure if they still call it vari drive but anyway, seemed like if you adjusted it too much, the belt would shred itself. And all I was using it for was to mow grass. In theory, it should work good. It's a similar idea to a torque converter clutch except that you vary the gearing yourself. I would guess if some changes were made to the design it could work better. But, I have no idea why they don't work stock and I don't think anyone wants to bother lol.
Austin_Gore
Austin_Gore
PostSubject: Re: Yard machine speed help   Yard machine speed help Icon_minitimeSeptember 9th 2019, 9:10 am
whats the best transaxle i can get fo cheap cause im 15 and im new to this stuff
Austin_Gore
Austin_Gore
PostSubject: Re: Yard machine speed help   Yard machine speed help Icon_minitimeSeptember 9th 2019, 9:15 am
what could i do to the trans axle to make it to where it "heavy duty" and is a fnr axle good for speed cause i was thinkin that it has all the gears "fnr" that ill really need and best bolts to use for front spindles??
PostSubject: Re: Yard machine speed help   Yard machine speed help Icon_minitimeSeptember 9th 2019, 9:50 am
FNR are pretty light weight. You can make them go faster with some mods and pulley swap. Making them stronger... lots of bracing?
Austin_Gore
Austin_Gore
PostSubject: Re: Yard machine speed help   Yard machine speed help Icon_minitimeSeptember 10th 2019, 9:04 am
what you mean bracing and best bolts to use for end of spindle replacment
PostSubject: Re: Yard machine speed help   Yard machine speed help Icon_minitimeSeptember 10th 2019, 10:18 am
Bracing of the transaxle would be anything to keep it from snapping in two when you hit a bump fast or hit rough terrain hard.
Quick search I found this in the forum.
Example of transaxle "end" bracing can be seen here:
Yard machine speed help EP1lesE
https://www.atltf.com/t3898p125-my-2003-murray-select-all-terrain-tractor-build
I've even seen some do a sort of brace that goes under the transaxle as well.  Anything to keep the axle straight.
As for best bolts for end of spindle replacement.  Not sure what you are asking here.  Are you making a spindle out of a bolt to mount a tire?  @AllisKidD21 has done that.  I would think any grade 5 or higher bolt would work the diameter of your bearings for your wheel.  Some are 5/8" some are 3/4" and as long as you need for your wheel to fit on.
Austin_Gore
Austin_Gore
PostSubject: Re: Yard machine speed help   Yard machine speed help Icon_minitimeSeptember 10th 2019, 11:12 am
how can i make the trans axle to where the wheels are held on by nuts not snaprings
darkside0914
darkside0914
2020 Build-Off Top 3 Winner
PostSubject: Re: Yard machine speed help   Yard machine speed help Icon_minitimeSeptember 11th 2019, 1:53 am
if you can weld, or have someone who can, you can weld a bolt to the end of the axle, or you can drill and tap the axle, this is the method i plan to use on a project i'm getting ready to start where i need a little more space between the wheel and transaxle housing
Sirironduke
PostSubject: Re: Yard machine speed help   Yard machine speed help Icon_minitimeSeptember 30th 2019, 5:26 pm
I'm in the process of doing a pully swap on my yard machines/ MTD. Looks easy enough to do both engine and transaxle. To do either one youl need a pully and a belt. My varidrive is working fine so I'm gona try and keep it as long as I can.
Austin_Gore
Austin_Gore
PostSubject: Re: Yard machine speed help   Yard machine speed help Icon_minitimeApril 18th 2020, 9:10 pm
did it work for you
» Yard Machine Traveling Tractor Top Speed Run
» MTD Yard Machine Build
» Update on the blown up yard machine
» Yard machine front travel
» 1998 mtd yard machine garden tractor
