| [Rules DQ] - James Yoder's Frankenstein 2.0 2019 build off entry [2019 Build-Off Entry] | |
+2MightyRaze Frankenstein 2.0 6 posters |
Frankenstein 2.0 New Member
2019 Build-Off Entrant
Age : 21 Join date : 2019-02-21 Points : 2108 Posts : 8 Location : ORANGEVILLE, PA
| Subject: [Rules DQ] - James Yoder's Frankenstein 2.0 2019 build off entry [2019 Build-Off Entry] February 23rd 2019, 2:19 pm | |
| I will be stretching the frame four inches, adding a 16hp oppy, custom stacks, full custom wiring with push button and kill switch, I'm stretching the frame four inches to fit the oppy with out hitting the peddles, I will be building a custom winch bumper, and maybe build a back bumper, I will be putting 23 inch AG's on the rear, I will have the gas tank under the rear seat and battery under hood and I will put led lights on the front bumper. And adding some type of aggressive front tires. I have a lot of work ahead of me! Approved: 2-25-2019 MightyRaze | |
Age : 23 Join date : 2018-02-27 Points : 3843 Posts : 1299
| Subject: Re: [Rules DQ] - James Yoder's Frankenstein 2.0 2019 build off entry [2019 Build-Off Entry] February 25th 2019, 5:21 pm | |
| A little birdy told me there might be front end suspension plans in the mix as well. Good luck James! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
1st Place Build-Off 2020
Age : 22 Join date : 2018-11-09 Points : 2850 Posts : 582 Location : Reeses Mill, WV
MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5750 Posts : 1993 Location : Northern Ireland
| Subject: Re: [Rules DQ] - James Yoder's Frankenstein 2.0 2019 build off entry [2019 Build-Off Entry] July 5th 2019, 11:28 pm | |
| [adm]Build in Probation.
Builds that have no update since creation, or several months no update will go into a "Build Probation" folder for not following the rules.
RULE: Entrants MUST update their thread at least monthly detailing progress, with either write-ups, videos and/or photos.
Builds still in this folder at the end of the build-off will automatically be deemed "Disqualified!" To have your build removed from the Probation, you will need to petition the Admin Team to have it taken back out no later than 30 days before competition end. Contact link is on the bottom of any ATLTF.COM page.
ATLTF Staff [/adm] | |
