| a tuff torq 7a545084160 | |
jcb75 New Member
Age : 49 Join date : 2018-09-10 Points : 2275 Posts : 12 Location : summerville ga
| Subject: a tuff torq 7a545084160 January 14th 2019, 10:20 pm | |
| Are the tiff torq 7a545084160 any good for a tractor build | |
| Subject: Re: a tuff torq 7a545084160 January 14th 2019, 10:31 pm | |
| I assume you are reffering to the Tuff Torq hydrostatic drive transaxles, and if so this post should've been made in the "Transaxles and Transmissions" section...
Anyways, to answer your question would require more information. What kind of tractor build? What all do you plan to be doing with it? What kinda of tires planned? Etc.
"This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
jcb75 New Member
| Subject: Re: a tuff torq 7a545084160 January 14th 2019, 10:38 pm | |
| I have a continental 4a032 air cooled opposed 4 cylinder from a military genset that I want to put on a nutty widebody and want a transaxle that will handle the torque of that engine afar as tire problem turf right now sorry about putting in the wrong place | |
| Subject: Re: a tuff torq 7a545084160 January 14th 2019, 10:47 pm | |
| Hmmm, that sounds like quite a power plant. Is is a vertical shaft lawn tractor transmission? If so you'd be probably be better off trying to use an old garden tractor transaxle with a horizontal pinion shaft.
Trying to use an old Cub Cadet transaxle would be really neat and one of those would hold up without question. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
jcb75 New Member
Crazy_Carl Veteran Member
| Subject: Re: a tuff torq 7a545084160 January 15th 2019, 3:43 pm | |
| I really don't think a tuff torq unit will handle all that power. I have one in my JD LT160 and it's really only meant for a low speed light duty lawn mower. I tried a mild pulley swap on it and it overheated after prolonged use. | |
jcb75 New Member
| Subject: Re: a tuff torq 7a545084160 January 15th 2019, 5:52 pm | |
| I very highly doubt an MST 205 would hold up with that engine. This is definitely a job for an old garden tractor transaxle. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
jcb75 New Member
| Subject: Re: a tuff torq 7a545084160 January 15th 2019, 5:58 pm | |
| OK here's the confusing thing about that tiff torq axle it has a stick to shift gears but it's a auto | |
| Subject: Re: a tuff torq 7a545084160 January 15th 2019, 6:16 pm | |
| Cub cadet would hold up, and is also shaft driven so the drivetrain layout would be really easy to put together. They’re out there, just gotta pay to play | |
| Subject: Re: a tuff torq 7a545084160 January 15th 2019, 6:25 pm | |
| It would be nice to see some pictures and to know what the axle size is on this specific tuff torq axle | |
jcb75 New Member
| Subject: Re: a tuff torq 7a545084160 January 15th 2019, 6:44 pm | |
| When I'm at my buddies house that has it I'll get some pics if I remember to | |
jcb75 New Member
jcb75 New Member
jcb75 New Member
jcb75 New Member
jcb75 New Member
| Subject: Re: a tuff torq 7a545084160 January 19th 2019, 10:46 pm | |
| OK here's something off the wall np435 granny gear 4spd and ford 8.8 narrowed | |
| Subject: Re: a tuff torq 7a545084160 January 19th 2019, 10:50 pm | |
| Now that sounds like a better plan for this kinda power plant! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
jcb75 New Member
| Subject: Re: a tuff torq 7a545084160 January 20th 2019, 12:37 am | |
| I'll start fitting parts when I can man alive this murry widebody is going to be a tank | |
