| | The Gilsonator!!!! | |
+4Crazy_Carl RichieRichOverdrive MightyRaze mrshaft696 8 posters | |
mrshaft696 Established Member
| Subject: Re: The Gilsonator!!!! April 8th 2019, 12:38 pm | |
| - Crazy_Carl wrote:
- Do you mean 3-point hitch? I see a place to mount the two lower links and the top link.
Making it lift...that's another story. I have seen someone successfully use a power steering pump to actuate a hydraulic cylinder. Where to mount it...I have no idea lol. Have you found any diagram or sales brochure on implements? the original one was electric, you can see the plug on the back of the tractor. I just need to get a class II receiver mounted up for what I need. | |
Age : 35 Join date : 2017-10-30 Points : 5299 Posts : 2561 Location : Rochester, New York
| Subject: Re: The Gilsonator!!!! April 8th 2019, 1:13 pm | |
| Oh you just need a 2" receiver and you already have fabrication equipment, well enough said. So you could weld up a 3 point mount similar to this simple one I made. Apparently the image server is looking for my e-mail and password which I don't have so I can't upload images ATM, but it's very similar to something you can buy or see people weld up on youtube.
Instead of having 3 link bars that can pivot like a standard 3 point hitch. You could weld 3 rigid links to the receiver that pin right in place with the 3 link mounts on your tractor. This requires careful measuring but the actual fabrication and welding parts are really simple.
Join date : 2016-07-10 Points : 4025 Posts : 870 Location : Phillydelphia
| | | | MightyRaze Administrator
| Subject: Re: The Gilsonator!!!! May 28th 2019, 8:51 am | |
| Great work. If you should mod it in the future, lower and closer to the axle will give you a little more stability. (no wheelies) | |
| Subject: Re: The Gilsonator!!!! May 28th 2019, 10:16 am | |
| - MightyRaze wrote:
- Great work. If you should mod it in the future, lower and closer to the axle will give you a little more stability. (no wheelies)
Thanks, I had to, well wanted to mount this one up where it is because there is no "frame" down low just the brackets that mount the transaxle. You can see where the frame stops just below my hitch side plate. It makes it a similar bumper height to my truck so I dont have to have multiple drop hitches etc.
| | | AllisKidD21 Moderator
Age : 25 Join date : 2016-07-10 Points : 8553 Posts : 5190 Location : Ontario Canada
| Subject: Re: The Gilsonator!!!! May 28th 2019, 10:21 am | |
| Sweet homemade receiver!! Looks like it should come in quite handy. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Who is online? | In total there are 10 users online :: 0 Registered, 0 Hidden and 10 Guests
