| 1969 MTD 960 Diesel build | |
+8RockeyDA RichieRichOverdrive Creepycrawler AllisKidD21 Double W Cross Ranch MatthewD Crazy_Carl SteamNut247 12 posters |
Crazy_Carl Veteran Member
SteamNut247 Member
Age : 28 Join date : 2016-12-14 Points : 2975 Posts : 70 Location : Duluth Minnesota
RockeyDA Established Member
Age : 30 Join date : 2017-10-15 Points : 3257 Posts : 639 Location : Bellefonte PA
| Subject: Re: 1969 MTD 960 Diesel build November 11th 2018, 9:18 pm | |
| some how my 990 is rougher on a trail than the ford wheeler as far as bumps go. is yours the same way? | |
SteamNut247 Member
| Subject: Re: 1969 MTD 960 Diesel build November 11th 2018, 9:20 pm | |
| @RockeyDA I am not sure my tractor is not in running condition right now. I think the main reason is your 990 and my 960 has no suspension besides the seat suspension. | |
| Subject: Re: 1969 MTD 960 Diesel build November 11th 2018, 9:25 pm | |
| my ford wheeler dont even have seat suspension, but i dont feel every little rock on the ford, maby its the fact i have car tires on my 990. but i feel every little thing on the 990. even if a rock gets stuck in a tread. | |
SteamNut247 Member
| Subject: Re: 1969 MTD 960 Diesel build November 11th 2018, 9:28 pm | |
| @RockeyDA the main reason why on your four wheeler you don't feel the rocks is they have a frame suspension, and that takes out the bumps. | |
SteamNut247 Member
Age : 37 Join date : 2013-07-02 Points : 5016 Posts : 731 Location : Logan Ohio
SteamNut247 Member
| Subject: Re: 1969 MTD 960 Diesel build December 20th 2018, 6:48 pm | |
| @Creepycrawler I do have one in mind,this project is on the back burner for now, I got some other projects i need to get done first.I will most likely take me about year and half to get the tractor done. | |
SteamNut247 Member
Age : 49 Join date : 2016-09-06 Points : 15660 Posts : 10979 Location : Oklahoma
Age : 22 Join date : 2016-10-29 Points : 7212 Posts : 4014 Location : Lewisburg, KY
| Subject: Re: 1969 MTD 960 Diesel build July 1st 2019, 7:07 am | |
| i want a 960. a MTD 960 and a subrubin with 18hp cast iron oppy are on my bucket list. tractors i want but will never find at a affordable price. | |
Age : 23 Join date : 2018-02-27 Points : 3843 Posts : 1299
SteamNut247 Member
| Subject: Re: 1969 MTD 960 Diesel build July 4th 2019, 11:03 am | |
| Happy July 4th the tiller and the snowblower are actual mtd implements, but the plow is a Brinly, the reason why I know this is I also got a brochure and the manual for the plow, snowblower, tiller, and the engine, which are really hard to find. My plan is to put the guts in blue one I got due the blue one has better tins, dash, and stickers. or the same respect just put all the good tins and dash on the one with the implements. the one I am going to get for parts has factory wheels weights, so when I am done I am going to have a trio of MTD 960/860 tractors, and only one or two are going to run. And I also did find out that the blue one is a 860 due it has a 12hp briggs instead of a 14hp briggs. here is the parts tractor I plan on getting: | |
Age : 20 Join date : 2017-06-09 Points : 5489 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: 1969 MTD 960 Diesel build July 8th 2019, 3:28 pm | |
| Sweet finds! I'm getting jealous over here too. Are all 3 going to be made into 1 diesel one or are you going to have a diesel one and a gas one? You can probably make 2 running ones easily. | |
SteamNut247 Member
| Subject: Re: 1969 MTD 960 Diesel build October 11th 2019, 10:47 am | |
- Sweet finds! I'm getting jealous over here too. Are all 3 going to be made into 1 diesel one or are you going to have a diesel one and a gas one? You can probably make 2 running ones easily.
Sorry for the late response, I have been dealing with my car that has been failing, I am going to make one running tractor out of the three, due parts are getting hard to find. plus I will be getting a Wheel Horse b-80 with mower deck, snowblower and a front blade. Plus I will have a 1988 MTD grass cutter tractor too, so three running tractors and a two parts will be enough for me. | |
Juscuz New Member
Join date : 2019-07-31 Points : 1969 Posts : 21 Location : West Michigan
SteamNut247 Member
Juscuz New Member
SteamNut247 Member
| Subject: Re: 1969 MTD 960 Diesel build October 26th 2019, 9:44 pm | |
| - Juscuz wrote:
- Very nice, I have a 30hp Wisconsin 4" pump
Got a couple of pictures? | |
Juscuz New Member
SteamNut247 Member
| Subject: Re: 1969 MTD 960 Diesel build October 26th 2019, 10:33 pm | |
| - Juscuz wrote:
- I will post some tomorrow, I don't have any on my phone.
do want a link to my tractor build playlist? | |
Juscuz New Member
SteamNut247 Member
